This is my rear light cluster block
http://img.photobucket.com/albums/v150/zetec_orion/Car/P100616001.jpg
Now the question i have is that i want to relace the standard rear lights with a set of quad lights. I tried this today and the wiring just looked a mess trying to get spade connectors into the holes as i really dont want to have to chop the block off. So is there another block prewired i can get to connect into this block?
Also when i had the quad lights on the fog light came on as a brake light. Do i take it that i need some sort of diode to stop this happening? if so which one?
you have to pull that red bit out. then get a small precision screwdriver in and push back a little tab on the spade connector then it should slide out. Its tricky and frustrating but possible
cheerz mate
