Posted June 18, 201014 yr Hi there guys.I did my 2.0 zetec conversion in my escort sport, and would just like to know how many miles/kilometers people het on a full tank(55L) ? Cause with the 1.6 on a very light foot I used to get 600km/361miles and with a bit heavy foot I got 450km/ 271miles.With the 2.0 I get 350km/210miles on a very very light foot(I pee everybody off in traffic) and with a heavyish foot I het 380km/228miles.This confuses me, I've check for any leaks and found non :-(Help please with any advice ? I have the 1.6 Intake with the 2.0 injectors and the 2.0 throttle bodie and a 1.8/2.0 mafThanx
June 18, 201014 yr So you get better fuel economy when driving hard? Sounds like a MAF or Oxygen sensor issue.
June 18, 201014 yr Author Thats correct , I'm still using the 1.6 ecu. I got a 1.8/2.0 maf but the sensor was stuffed, the car wouldn't idle. so I took the 1.6 sensor and stuck it in the 2.0 maf and it worked fine then,the car pulls right through to red line and doesn't have a missfire so I geuss the maf is okey? anyway I can check it?
June 18, 201014 yr Author You need a 2.0L ECU - car on non correct engine management = fail.a Unichip ecu is also on my todo after the brakes.... anyways you think its the ecu ?
June 18, 201014 yr yes, its the ECU. its not designed to run to run a 2.0 maf ECT. Change it for a DEEP, DALE, DEWY or DESK mate
June 18, 201014 yr I also changed the lamda sensor, for a 2.0 one, check the parts numbers to see they are different. 1.8 inlet is better too
June 19, 201014 yr The oxygen sensors are the same.. in function.. Wrong ECU will cause running issues.
June 19, 201014 yr Author So I checked the maf, its working fine , and changed the coilpack (read that may also cause bad fuel economy) and the car doesn't have any running problems thats why I thought the 1.6 ecu will work fine for now and it does except for the heavy guzzeling fuel... so if this fails its a new management system :-) thanx for the help guys
