just fitted a 2.0 mk1 mondeo engine in my escort gti and got it all in and wat not but doesnt seem to want to idle i have used my ecu and the 2.0 injectors my inlet and 2.0 maf sensors could do with a vacuum pipe diagram if anyone has one or any advise
Just like all the gazillion threads of this nature, running the wrong ECU will lead to problems.
got the 1.8 ecu on wen it get to 3,000 rpm it seems fine
You need the 2.0 injectors that match the 2.0 ecu & maf. Sort those out first.
iv 2 litre injectors maf sensor thorttle body on my 1.8 inlet manifold 1.8 crank sensor and the rest of the sensors 2 ltr plug leads and plugs gti gearbox and clutch gti waterpump, oil pump and sump running on a 1.8 ecu but had a friend run a 2 ltr fine one 1.6 ecu ??
You can keep repeating that all you want fella but the facts will stay the same, Stu and Jc have both told you what you need to do, either take their experienced advice to hand and do as they suggest or ignore them and keep randomly trying to trace the fault until you eventually end up right back at the point they told you to address.
incase your missing the point they KNOW what their talking about despite whatever your freind has done or tells you. :thumb:
my fiesta has the 2.0ltr mondeo in it thats running 2.0 ltr throttle plate 2.0 injectors 2.0 ltr maf sensore and 1.6 ecu and 1.6 inlet and a part from the lumpy idle ( between 900 and 1000 ) its runs fine and taps on abit you must have another problem mate because it would still idle on that ecu even if it runs like a bag of crap try unplugging the maf and try agen ?
So it doesn't idle properly and taps... yet you say it runs fine??? ?(
