jghs83 Posted August 12, 2010 Share Posted August 12, 2010 as it says guys and gals, how would i go about fitting a set of mondeo mk2 st24 callipers, discs and pads to my escort van? what else is needed? different brakes lines perhaps? does anything need drilling out like the st170 brake conversion? thanks in advance Link to comment Share on other sites More sharing options...
Hezz Posted August 12, 2010 Share Posted August 12, 2010 search and you shall know - loads of topics on it and a few good ones too! Link to comment Share on other sites More sharing options...
Craig855S Posted August 13, 2010 Share Posted August 13, 2010 Use escort cosworth front discs (not expensive from a good motor factor) Drill the hubs out to 12mm, fit some washers between the hub and carrier, and use mondeo brake hoses Link to comment Share on other sites More sharing options...
jghs83 Posted August 14, 2010 Author Share Posted August 14, 2010 Use escort cosworth front discs (not expensive from a good motor factor) Drill the hubs out to 12mm, fit some washers between the hub and carrier, and use mondeo brake hoses thanks hubs drilled out, check spacers for discs and carrier being made, check mondeo st24 brake hoses, check Link to comment Share on other sites More sharing options...
Craig855S Posted August 14, 2010 Share Posted August 14, 2010 I dont know how much you space the mondeo discs by, which is why its better to use cossie ones, and the calipers im unsure about too if your gonna use the mondeo discs, all i know is we had a wide range of washers avalilable to hand and used 2 fat ones and 1 thin one (worked out at 4.5-5mm of spacing) per carrier bolt...Used in conjunction with the cossie discs it made it fit perfect. Link to comment Share on other sites More sharing options...
