mrfixit Posted August 19, 2010 Share Posted August 19, 2010 i have got a power boost valve i havent fitted it yet . my question is are thay any good as any one got one fitted do thay make any difference if set up right if thay do can any one help with a how to fit it thanks john Link to comment Share on other sites More sharing options...
Stu Posted August 19, 2010 Share Posted August 19, 2010 What problem are you trying to fix with this valve? Link to comment Share on other sites More sharing options...
mrfixit Posted August 19, 2010 Author Share Posted August 19, 2010 What problem are you trying to fix with this valve?flat spots Link to comment Share on other sites More sharing options...
Stu Posted August 19, 2010 Share Posted August 19, 2010 What problem are you trying to fix with this valve?flat spots You actually have a flat spot, or you're just going by what the FSE advert/box says it fixes? Link to comment Share on other sites More sharing options...
mrfixit Posted August 19, 2010 Author Share Posted August 19, 2010 What problem are you trying to fix with this valve?flat spots You actually have a flat spot, or you're just going by what the FSE advert/box says it fixes?yes it pull back at about 3 grand than go's again Link to comment Share on other sites More sharing options...
Stu Posted August 19, 2010 Share Posted August 19, 2010 Then you have a problem with your car. It didn't do that when it left the factory so really you should look at resolving whatever the issue is than buying aftermarket snake oil. Any sensor on the car when faulty can cause 'flat spots'. Air leaks on the inlet tract can too (in relation to MAF). Best to get a garage to diagnose which sensor is faulty rather than you potentially wasting more money randomly replacing them one by one until it (hopefully) goes away. Link to comment Share on other sites More sharing options...
mrfixit Posted August 19, 2010 Author Share Posted August 19, 2010 Then you have a problem with your car. It didn't do that when it left the factory so really you should look at resolving whatever the issue is than buying aftermarket snake oil. Any sensor on the car when faulty can cause 'flat spots'. Air leaks on the inlet tract can too (in relation to MAF). Best to get a garage to diagnose which sensor is faulty rather than you potentially wasting more money randomly replacing them one by one until it (hopefully) goes away.i got my own fault code reader and it dos not report any think wrong with the sensors or any think else plus i have a vacume guage that dont show any leaks Link to comment Share on other sites More sharing options...
alexc1983 Posted August 19, 2010 Share Posted August 19, 2010 yet another tuning con with false claims! dont bother mate. I had similar issues with lambda sensor, engine overfuelling it seemed. Check all your sensors Link to comment Share on other sites More sharing options...
Stu Posted August 19, 2010 Share Posted August 19, 2010 i got my own fault code reader and it dos not report any think wrong with the sensors or any think else plus i have a vacume guage that dont show any leaks A sensor can fail "in range" and not flag up a code on your scanner, yet still cause a running issue. Link to comment Share on other sites More sharing options...
mrfixit Posted August 19, 2010 Author Share Posted August 19, 2010 yet another tuning con with false claims! dont bother mate. I had similar issues with lambda sensor, engine overfuelling it seemed. Check all your sensorsi have had the car on diagnostics computer there are no faults with the engine at all Link to comment Share on other sites More sharing options...
Stu Posted August 19, 2010 Share Posted August 19, 2010 yet another tuning con with false claims! dont bother mate. I had similar issues with lambda sensor, engine overfuelling it seemed. Check all your sensorsi have had the car on diagnostics computer there are no faults with the engine at all There's a fault with something if you have a noticeable 'flat spot'. If you've already made your mind up that this valve is going to fix all your 'problems', then just say and we'll tell you what you want to hear. Link to comment Share on other sites More sharing options...
Trig Posted August 19, 2010 Share Posted August 19, 2010 Then you have a problem with your car. It didn't do that when it left the factory so really you should look at resolving whatever the issue is than buying aftermarket snake oil. Any sensor on the car when faulty can cause 'flat spots'. Air leaks on the inlet tract can too (in relation to MAF). Best to get a garage to diagnose which sensor is faulty rather than you potentially wasting more money randomly replacing them one by one until it (hopefully) goes away.i got my own fault code reader and it dos not report any think wrong with the sensors or any think else plus i have a vacume guage that dont show any leaks Code reader wont tell you that the cat is a bit blocked, the MAF isnt working properly or if there is an air leak on the inlet somewhere. It needs closer looking at i f the flat spot is anything more than normal (zetecs do have a natural flatspot) then I wouldnt be looking at fitting a FSE valve, all you do with that is risk ruining the fuel pressure. Link to comment Share on other sites More sharing options...
mrfixit Posted August 19, 2010 Author Share Posted August 19, 2010 the car drives alright there is no fuelling problems it ticks over alright the engine is sound the only thing is when i try to over take she holds back then gos now i understand this to be a flat spot around 3000 revs i have also read it that this is common on gti Link to comment Share on other sites More sharing options...
Stu Posted August 19, 2010 Share Posted August 19, 2010 zetecs do have a natural flatspot You mean this barely noticeable dip in the power curve? http://di.cx/gallery/d/5489-2/eec_vs_ms_rr_01.jpg I doubt anyone is really feeling that in the car. Link to comment Share on other sites More sharing options...
mrfixit Posted August 19, 2010 Author Share Posted August 19, 2010 Then you have a problem with your car. It didn't do that when it left the factory so really you should look at resolving whatever the issue is than buying aftermarket snake oil. Any sensor on the car when faulty can cause 'flat spots'. Air leaks on the inlet tract can too (in relation to MAF). Best to get a garage to diagnose which sensor is faulty rather than you potentially wasting more money randomly replacing them one by one until it (hopefully) goes away.i got my own fault code reader and it dos not report any think wrong with the sensors or any think else plus i have a vacume guage that dont show any leaks Code reader wont tell you that the cat is a bit blocked, the MAF isnt working properly or if there is an air leak on the inlet somewhere. It needs closer looking at i f the flat spot is anything more than normal (zetecs do have a natural flatspot) then I wouldnt be looking at fitting a FSE valve, all you do with that is risk ruining the fuel pressure.i have not check the cat i have fitted a new exhaust from the cat back i might fit a new cat zetecs do have a natural flatspot You mean this barely noticeable dip in the power curve? http://di.cx/gallery/d/5489-2/eec_vs_ms_rr_01.jpg I doubt anyone is really feeling that in the car.i take it that the top line shows the flat spot between 3000 revs and 3500rev well that were i notice it Link to comment Share on other sites More sharing options...
