alexc1983 Posted August 20, 2010 Share Posted August 20, 2010 hi people, does the 1.6 have an egr valve? and if so, where is it located? cheers Link to comment Share on other sites More sharing options...
SteveB Posted August 20, 2010 Share Posted August 20, 2010 hi people, does the 1.6 have an egr valve? and if so, where is it located? cheers Early ones yes - late ones no. Look for 4 metal pipes coming from the exhaust manifold and going to a metal box. The box is the valve. Link to comment Share on other sites More sharing options...
alexc1983 Posted August 20, 2010 Author Share Posted August 20, 2010 hi people, does the 1.6 have an egr valve? and if so, where is it located? cheers Early ones yes - late ones no. Look for 4 metal pipes coming from the exhaust manifold and going to a metal box. The box is the valve. mine is an s-reg, i assume it probably doesnt. Does it have any EGR system? Link to comment Share on other sites More sharing options...
SteveB Posted August 20, 2010 Share Posted August 20, 2010 hi people, does the 1.6 have an egr valve? and if so, where is it located? cheers Early ones yes - late ones no. Look for 4 metal pipes coming from the exhaust manifold and going to a metal box. The box is the valve. mine is an s-reg, i assume it probably doesnt. Does it have any EGR system? That year will be a single pipe (not 4 pipes) if it has EGR. I've circled the EGR valve on this photo. http://158.143.56.200/~steve/egr.jpg Link to comment Share on other sites More sharing options...
alexc1983 Posted August 20, 2010 Author Share Posted August 20, 2010 hi people, does the 1.6 have an egr valve? and if so, where is it located? cheers Early ones yes - late ones no. Look for 4 metal pipes coming from the exhaust manifold and going to a metal box. The box is the valve. mine is an s-reg, i assume it probably doesnt. Does it have any EGR system? That year will be a single pipe (not 4 pipes) if it has EGR. I've circled the EGR valve on this photo. http://158.143.56.200/~steve/egr.jpg ok cheers for picture, tho it looks as tho mine doesnt have one then. Link to comment Share on other sites More sharing options...
