JbirdGTi Posted August 21, 2010 Share Posted August 21, 2010 (edited) Right where do i start, seems like when eva i fix 1 problem another one jus happenes to appear Basicly my mk6 decides when it wants to start? i can turn the key all the way and nothing happens (and i mean nothing), all the light come up on the dash and the stereo turns on so its not the battery and iv checked and still got all the volts. Now its fine 8 times out of 10 but i have no idea what it is. 1st time it happened i jus took the key out, put the steering lock on and try again and it worked.2nd time i kept tryin the key and then it randomly started.3rd time nothin for a while so i tryed takin the negative off the battery waited 15mis and the put it bak on and it worked 1st time.This time did the same with takin the battery off and left it like 45mins and nothin ...... and still nothing today???? ANY HELP WOULD BE GREATFUL Edited August 21, 2010 by JbirdGTi Link to comment Share on other sites More sharing options...
shawdreamer Posted August 21, 2010 Share Posted August 21, 2010 Right where do i start, seems like when eva i fix 1 problem another one jus happenes to appear Basicly my mk6 decides when it wants to start? i can turn the key all the way and nothing happens (and i mean nothing), all the light come up on the dash and the stereo turns on so its not the battery and iv checked and still got all the volts. Now its fine 8 times out of 10 but i have no idea what it is. 1st time it happened i jus took the key out, put the steering lock on and try again and it worked.2nd time i kept tryin the key and then it randomly started.3rd time nothin for a while so i tryed takin the negative off the battery waited 15mis and the put it bak on and it worked 1st time.This time did the same with takin the battery off and left it like 45mins and nothin ...... and still nothing today???? ANY HELP WOULD BE GREATFUL coil pack? Link to comment Share on other sites More sharing options...
mclovin9091 Posted August 21, 2010 Share Posted August 21, 2010 Dodgy connection at the alternator, bad earth. When it starts does it do it easily or after a bit of a struggle. Im also in the same fixing boat just with other problems Link to comment Share on other sites More sharing options...
JC Posted August 21, 2010 Share Posted August 21, 2010 Could be lots of things? Are you in the RAC? when I had the same prob turned out to be a dead relay! Link to comment Share on other sites More sharing options...
JbirdGTi Posted August 21, 2010 Author Share Posted August 21, 2010 Its jus the fact that theres no attempt 4 the engine 2 crank ova atall, iv herd it could be my starter motor or crank position sensor, but its started now and i have no idea when its goin 2 do it again? Dont think it could be anythin 2 do with battery coz i get all the lights up on the dash, plus iv check the connection and its all good. Link to comment Share on other sites More sharing options...
