mac456 Posted September 5, 2010 Author Share Posted September 5, 2010 Surely the flat washer should be first, the purpose of the spring washer's to stop it loosening. i havnt got a clue mate, i just went from the diagram and still got it wrong. lol. iv decided to leave it for the time being as im moving house next year anyway. Thanks people Link to comment Share on other sites More sharing options...
rs2k2008 Posted September 5, 2010 Share Posted September 5, 2010 if you aint sure, torque it up to ft setting. (Fcuking tight) Link to comment Share on other sites More sharing options...
PeeWee Posted September 5, 2010 Share Posted September 5, 2010 if you aint sure, torque it up to ft setting. (Fcuking tight) Not always a great idea. If the washers are on the incorrect sides its most likely that overtightning the bolt will destroy the tubuler design. The parts are usually hollow hence forcing the nut to ruin the hole & pop right through the metal, hence the washer needed. Link to comment Share on other sites More sharing options...
danposs86 Posted September 5, 2010 Share Posted September 5, 2010 If you are worried, just get your tool set out again and get it fixed. Link to comment Share on other sites More sharing options...
HIGHTOWER Posted September 7, 2010 Share Posted September 7, 2010 I would have thought the flat washer should go on first, too, so I'd say it's the rest of the bolts wrong... I wouldn't loose any sleep over it, though! Link to comment Share on other sites More sharing options...
