lips2k9 Posted September 10, 2010 Share Posted September 10, 2010 I have wired up the rear fogs to the mk6 switch following wiring instructions found on net and basicly the fogs only stay lit if i hold the switch in - my first thaught was the switch is faulty so i tried 2 others and still had the same problem. Any idea? relay? Wrong wiring? come on guys need this to get MOT'd and on the road !!! Link to comment Share on other sites More sharing options...
escrt1.4i Posted September 11, 2010 Share Posted September 11, 2010 i would say relay related Link to comment Share on other sites More sharing options...
lips2k9 Posted September 11, 2010 Author Share Posted September 11, 2010 i would say relay related any idea what relay is for the rear fogs on a j reg mk5? Link to comment Share on other sites More sharing options...
mclovin9091 Posted September 11, 2010 Share Posted September 11, 2010 I think you will have to switch the wires around with each othere until you find the combination that works. I had this problem with mine when i installed the dual fog switch when i hooked up the front fogs on my mk6. Unfortunatley i can't remember which ones were swapped and can't get to the car either to look. Link to comment Share on other sites More sharing options...
lips2k9 Posted September 11, 2010 Author Share Posted September 11, 2010 I think you will have to switch the wires around with each othere until you find the combination that works. I had this problem with mine when i installed the dual fog switch when i hooked up the front fogs on my mk6. Unfortunatley i can't remember which ones were swapped and can't get to the car either to look. well there is two grey and yellow wires but when I swap them over the rear fogs dont work at all... I have been trying to get this working for nearly 2 weeks now and its really starting to get me down, has anybody here done a mk5 to mk6 dash conversion? surely somebody has and knows what to do? Link to comment Share on other sites More sharing options...
