16Vrhys Posted September 13, 2010 Share Posted September 13, 2010 (edited) which bulbs do i need to fit into my clock to illuminate it red? i want to fit new led bulbs into the speedo unit to light it up all red , is there any filters that has to be removed , how do u remove them with out doing any damage how hard is it to fit RED leds into heater controls whats needed Edited September 14, 2010 by PeeWee Link to comment Share on other sites More sharing options...
tigerst24 Posted September 14, 2010 Share Posted September 14, 2010 which bulbs do i need to fit into my clock to illuminate it red? i want to fit new led bulbs into the speedo unit to light it up all red , is there any filters that has to be removed , how do u remove them with out doing any damage how hard is it to fit RED leds into heater controls whats needed hi mate u can fit everything with led lights just order them off ebay, then u would need a soldering ironand some solder. but there really fiddley to do . so i found it to hard to do and even when i did them correctly some of them didnt work, so there is a guy on ebay that sells them already complete in the switches.as for the speedo lights i did these myself and yes there is a green filter in the unit so i got a dremmel and drilled them outand put my coloured leds in , once you get the speedo out u will see all the screws to undo etc.hope that helps thanks yvonne Link to comment Share on other sites More sharing options...
