Scort_CVH Posted September 15, 2010 Share Posted September 15, 2010 Alright peeps ive been told to buy parts (as the cars tipped a valve ) So im getting inlet £9.99 and exhaust valves £9.99 (2 of each as its currently unknown as to which ones are damaged)(Ebay)Head bolt set £12.40 (Euro car parts) Now heres what im stuck with i need to get a headgasket, exhaust manifold gasket and camcover gasket so the question is do these come in the Head Gasket Sets that im seeing on ebay? (1.6 Zetec) Any advice as to what i need and where to get it from would be greatly appreciated Link to comment Share on other sites More sharing options...
Stu Posted September 15, 2010 Share Posted September 15, 2010 I wouldn't buy anything until you've got the head off and checked the damaged. Might have cracked a guide or even a piston. Link to comment Share on other sites More sharing options...
Scort_CVH Posted September 15, 2010 Author Share Posted September 15, 2010 I wouldn't buy anything until you've got the head off and checked the damaged. Might have cracked a guide or even a piston. would it still run if it had done any of those? it clears over 3/4k revs but is poor at idle Link to comment Share on other sites More sharing options...
Stu Posted September 15, 2010 Share Posted September 15, 2010 Can you explain in detail how you have gotten to this point? Eg the diagnosis? Symptoms? Link to comment Share on other sites More sharing options...
Scort_CVH Posted September 15, 2010 Author Share Posted September 15, 2010 Can you explain in detail how you have gotten to this point? Eg the diagnosis? Symptoms? The timing belt came loose. We put on a new timing belt kit and re-aligned the timing, the car runs but is very lumpy uptill about 3/4k revs then drives as normal. I took it to a garage they said its running badly as they think its tipped a valve because when you unplug the injector at low revs nothing changes but when you raise the revs and plug it back in it sounds smoother. Sorry thats just me trying to remember, and as i use the car everyday i was going to try and get the parts so once its stripped down it can get the new valves, skimmed, gaskets and put back on. but what i think ill do is get it stripped down and inspected, send it off for skimming and buy the parts while its away Link to comment Share on other sites More sharing options...
Stu Posted September 15, 2010 Share Posted September 15, 2010 Sounds like cam timing is out to me. If you had a bent valve you're be able to hear it. A compression test would be a useful test too. Link to comment Share on other sites More sharing options...
scottg17 Posted September 15, 2010 Share Posted September 15, 2010 (edited) may not be timed up correctly, but, i bought a head kit from ebay when i replaced a valve on my old 1.6 The kit i bought seemed to be of fair quality. the car run fine with this kithttp://cgi.ebay.co.uk/FORD-ESCORT-FIESTA-M...5#ht_1369wt_911 ... stu beat me too it was too busy looking for the set on ebay Edited September 15, 2010 by scottg17 Link to comment Share on other sites More sharing options...
mrfixit Posted September 15, 2010 Share Posted September 15, 2010 get a Cylinder Leakage Test done this will tell you what valve if any inlet outlet what cylinder as a problem Link to comment Share on other sites More sharing options...
stoney Posted September 15, 2010 Share Posted September 15, 2010 Sounds like cam timing is out to me. If you had a bent valve you're be able to hear it. A compression test would be a useful test too. +1 if u do have a bent valve u do know u can just take one out and put another in they have to be re ground and so do the seats. i would get a head off of a gd runner and bamg it on with a new belt kit and head gasket personaly Link to comment Share on other sites More sharing options...
Scort_CVH Posted September 15, 2010 Author Share Posted September 15, 2010 Thanks for all the replies, I'll try and get some of the tests done. @Stoney yeah I know they've got to be cut in but that's no biggy I remember doing 16 on a rover head lol Link to comment Share on other sites More sharing options...
stoney Posted September 16, 2010 Share Posted September 16, 2010 45 degrees on valve face and 46 on valve seat btw Link to comment Share on other sites More sharing options...
