16Vrhys Posted September 17, 2010 Share Posted September 17, 2010 got an air leak when turn car off can hear it on my escort 1.6 98 , can any one point me in right place to look to try find the air leak Link to comment Share on other sites More sharing options...
MCCORNY11 Posted September 17, 2010 Share Posted September 17, 2010 a tip from my friend was spray break cleaner and when the revs increase you have found the leak! Link to comment Share on other sites More sharing options...
stoney Posted September 17, 2010 Share Posted September 17, 2010 if its plastic inlet odds on its the breather pipe at the back of the manifold that comes to the metal pipe just above the coil pack. common problem the degrade and split / collapse still available from ford think mine cost about 10 quid also check connections on plastic hose on brake sevo and the other end on the manifold. Link to comment Share on other sites More sharing options...
16Vrhys Posted September 18, 2010 Author Share Posted September 18, 2010 if its plastic inlet odds on its the breather pipe at the back of the manifold that comes to the metal pipe just above the coil pack. common problem the degrade and split / collapse still available from ford think mine cost about 10 quid also check connections on plastic hose on brake sevo and the other end on the manifold. facebook like! lol cheers 4 the reply Link to comment Share on other sites More sharing options...
