ganges Posted September 18, 2010 Share Posted September 18, 2010 a bit hard to describe so bear with with me, right changing from second to third (only time it happens), slight grating just as i push it into third, clutch not slipping, and it does not do it all the time, would i be right to think thrust bearing and if so, any idiea how much to fix, and how long, and is it an easy fix for a DIY person like me???, thanks in advance guys and girls Link to comment Share on other sites More sharing options...
mrfixit Posted September 18, 2010 Share Posted September 18, 2010 a bit hard to describe so bear with with me, right changing from second to third (only time it happens), slight grating just as i push it into third, clutch not slipping, and it does not do it all the time, would i be right to think thrust bearing and if so, any idiea how much to fix, and how long, and is it an easy fix for a DIY person like me???, thanks in advance guys and girlsif its the thrust bearing m8 than it gear box out Link to comment Share on other sites More sharing options...
ganges Posted September 18, 2010 Author Share Posted September 18, 2010 a bit hard to describe so bear with with me, right changing from second to third (only time it happens), slight grating just as i push it into third, clutch not slipping, and it does not do it all the time, would i be right to think thrust bearing and if so, any idiea how much to fix, and how long, and is it an easy fix for a DIY person like me???, thanks in advance guys and girlsif its the thrust bearing m8 than it gear box out that dont sound cheap, if it was thrust bearing would it only do it in the 2nd to third gear, if it had only just started to go??? Link to comment Share on other sites More sharing options...
stoney Posted September 25, 2010 Share Posted September 25, 2010 (edited) sounds more like a worn 3rd gear syncro imo Edited September 25, 2010 by stoney Link to comment Share on other sites More sharing options...
ganges Posted September 26, 2010 Author Share Posted September 26, 2010 sounds more like a worn 3rd gear syncro imo funny you should say that, a mate of mine said the same thing, any idea on price, or would i be better off getting a recon gearbox, and again any idea of price thanks Link to comment Share on other sites More sharing options...
stoney Posted September 26, 2010 Share Posted September 26, 2010 sounds more like a worn 3rd gear syncro imo funny you should say that, a mate of mine said the same thing, any idea on price, or would i be better off getting a recon gearbox, and again any idea of price thanks speak to heavyrightfoot aka wayne iam sure he would have a gd quality used unit he would do u cheaply and as for fitting it alldepends on your requiremnt once removed ie, ideally you would replace clutch and thrust bearing whilst gear box is out this is up to u but is highly recomended tbh and also labour rates at a garage where u live or weather or not u and your mates would be tackling this. the only specialist tool u would require is a clutch alignment tool if u was to replace the clutch itself. i myslef would chrage around 150 for fitting/removal regardless of weather or not the clutch would be replaced as its not a long job to do.so working on that. say 50 for gearbox70 clutch kit150 labour.270 ish this is only a rough idea u could find it to be dearer or cheaper all depnends hope this helps Link to comment Share on other sites More sharing options...
ganges Posted September 26, 2010 Author Share Posted September 26, 2010 sounds more like a worn 3rd gear syncro imo funny you should say that, a mate of mine said the same thing, any idea on price, or would i be better off getting a recon gearbox, and again any idea of price thanks speak to heavyrightfoot aka wayne iam sure he would have a gd quality used unit he would do u cheaply and as for fitting it alldepends on your requiremnt once removed ie, ideally you would replace clutch and thrust bearing whilst gear box is out this is up to u but is highly recomended tbh and also labour rates at a garage where u live or weather or not u and your mates would be tackling this. the only specialist tool u would require is a clutch alignment tool if u was to replace the clutch itself. i myslef would chrage around 150 for fitting/removal regardless of weather or not the clutch would be replaced as its not a long job to do.so working on that. say 50 for gearbox70 clutch kit150 labour.270 ish this is only a rough idea u could find it to be dearer or cheaper all depnends hope this helps many thanks for that, gives me a guide, car only done 67,000 on a "v" engine sound, so might go down that route, many thanks for your in-put Link to comment Share on other sites More sharing options...
