mrfixit Posted September 22, 2010 Share Posted September 22, 2010 i have a cat back system and the mid box silencer wadding in side the box is moving back and forth is there any way to solve this any ideas thanks Link to comment Share on other sites More sharing options...
stoney Posted September 23, 2010 Share Posted September 23, 2010 Take it by your fault its a magnex cat back. if so its not the wadding its the actual baffells and yes u can sort it. i actualy tooko my box off slit the welds open were the pipes go in to the box knocked the pipe further into the box to act as a clamp on the baffels( u have to do this both ends of the box ) rewelded it back up and its still goin fine now 2yrs later infact ted has my carand has not mentioned any thing. Link to comment Share on other sites More sharing options...
mrfixit Posted September 24, 2010 Author Share Posted September 24, 2010 Take it by your fault its a magnex cat back. if so its not the wadding its the actual baffells and yes u can sort it. i actualy tooko my box off slit the welds open were the pipes go in to the box knocked the pipe further into the box to act as a clamp on the baffels( u have to do this both ends of the box ) rewelded it back up and its still goin fine now 2yrs later infact ted has my carand has not mentioned any thing. thanks for you reply and yes it is a magnex i have cut a hole in it and the wadding gone hard and as clumped up there is no baffells just a perforated tube the wodding was moving up and down the box i am going to fit new wadding and weld it back up Link to comment Share on other sites More sharing options...
stoney Posted September 25, 2010 Share Posted September 25, 2010 Take it by your fault its a magnex cat back. if so its not the wadding its the actual baffells and yes u can sort it. i actualy tooko my box off slit the welds open were the pipes go in to the box knocked the pipe further into the box to act as a clamp on the baffels( u have to do this both ends of the box ) rewelded it back up and its still goin fine now 2yrs later infact ted has my carand has not mentioned any thing. thanks for you reply and yes it is a magnex i have cut a hole in it and the wadding gone hard and as clumped up there is no baffells just a perforated tube the wodding was moving up and down the box i am going to fit new wadding and weld it back up this is the baffels as it allows the air into the wadding Link to comment Share on other sites More sharing options...
