niki6969000 Posted September 26, 2010 Share Posted September 26, 2010 Hi all i have removed rear rubber seal to respray tailgate.mk6 5 door ,problem is i cant re-fit rubber properly,der.I would be greatful for any tips.Its been de badged de/locked and smoothed off and re-sprayed by myself,looks the nuts just need to fit rubber and fit...pics to follow. Link to comment Share on other sites More sharing options...
JC Posted September 26, 2010 Share Posted September 26, 2010 How do you mean can't refit? does it seem too long or does it no re fit into the gap? Link to comment Share on other sites More sharing options...
PeeWee Posted September 26, 2010 Share Posted September 26, 2010 (edited) Very often dirt & muck gets under these seals. It might be worth cleaning the inner of the seal and also the surface then try again. Bit of washing up liquid on the metal surface to aid the rubber slipping on could help. Edited September 26, 2010 by PeeWee Link to comment Share on other sites More sharing options...
niki6969000 Posted September 27, 2010 Author Share Posted September 27, 2010 How do you mean can't refit? does it seem too long or does it no re fit into the gap?Its very tight, been advised to use soapy water,had a little go tonight seems to be working .Thanks Link to comment Share on other sites More sharing options...
shawdreamer Posted September 27, 2010 Share Posted September 27, 2010 How do you mean can't refit? does it seem too long or does it no re fit into the gap?Its very tight, been advised to use soapy water,had a little go tonight seems to be working .Thanks high tension fishing cord trick not appropriate here? google it. its a obvious and well used trick of the trade. Link to comment Share on other sites More sharing options...
