DeeJay Posted October 23, 2010 Share Posted October 23, 2010 What have you done with your cables on your wall mounted TV's, I dont want to see any sign that they are there my TV is mounted onto solid block just looking for different idea's Link to comment Share on other sites More sharing options...
LiamGTR Posted October 23, 2010 Share Posted October 23, 2010 ~I use a cable tidy, it 'hugs' all my cables together into one tube so i've just got one thin tube going down the wall. Link to comment Share on other sites More sharing options...
PeeWee Posted October 23, 2010 Share Posted October 23, 2010 Not mine, but a friend had theirs buried into the wall. More work but perfect solution. You could surface mount trunking and paint it the colour of the wall, not invisible but far better than trailing wires. Link to comment Share on other sites More sharing options...
Craig855S Posted October 23, 2010 Share Posted October 23, 2010 I've surface mounted some conduit to get the leads up to my projector. Id recomend that along with the painting of the conduit.. If you own the home and always plan on having the TV on that wall then you could put them behind the wall and use a breakout box by you sky/virgin/whatever to get the cables into the wall. Link to comment Share on other sites More sharing options...
EscortNreg Posted October 23, 2010 Share Posted October 23, 2010 Ikea sell stuff that runs down the wall, it's about 6 inches wide in a subtle dome, when you paint or wall paper over it, you can hardly see its there. Link to comment Share on other sites More sharing options...
Andyb0127 Posted October 24, 2010 Share Posted October 24, 2010 Sunk all mine into the wall is alot more work but you can't see any wires at all but that's coz I don't like conduit you can see it even if it's painted, it's down to personal preference how you want it to look. Link to comment Share on other sites More sharing options...
DeeJay Posted October 24, 2010 Author Share Posted October 24, 2010 Cheers for the replys i think im going to to build a fake chimney breast, made from timber and plasterboard, not far out from the wall but with enough room to put cables down, this way i will still be able to access the cables if ever i need to replace or add more. ill let you know how it goes. Link to comment Share on other sites More sharing options...
sortedford Posted October 24, 2010 Share Posted October 24, 2010 I have a false wall its mounted on, built in a recess with 2x2 battons, faced with MDF. Theres a supportless shelf at the top which DVDs etc can sit on, and the centre speaker. This meant the false bit didnt have to dgo to the celing, and gives the illusion that its just the wall. http://img.photobucket.com/albums/v206/sortedford/tv.jpgIgnor the Xbox cables that you can see, that isnt normally its home Link to comment Share on other sites More sharing options...
duffa Posted October 24, 2010 Share Posted October 24, 2010 B&Q sell a conduit thats about 2"-3" wide thats paintable for around £15 for 3 metres i'll try and upload a picture later on , fitted all this in from my set up .... 3x coax cables , 2 sky cables , 2 power leads , VGA cable , audio lead and 7x speaker cables ...with room to spare Link to comment Share on other sites More sharing options...
