chrisxn Posted October 25, 2010 Share Posted October 25, 2010 Ok, I've returned to this forum cos the people on the other forum are useless and I trust you people! I wanna fit some VW alloys to my civic. Offset and PCD are fine, but the centre bore is out. The VW wheels are 1mm larger. Will this make a difference or should I try and source some 1mm spigot rings? Thanks!! Chris Link to comment Share on other sites More sharing options...
16Vrhys Posted October 26, 2010 Share Posted October 26, 2010 1mm larger spigot rings to support the weight of the alloys against the hub and not on its wheel bolts and studs. Link to comment Share on other sites More sharing options...
