TIL13R Posted November 5, 2010 Share Posted November 5, 2010 As titled i have been offered Calipers, Carriers, Disk and Pads for ST170 just wat to know if it is a direct fit onto my RS2k....?? Cheers Tiller Link to comment Share on other sites More sharing options...
hicksy Posted November 5, 2010 Share Posted November 5, 2010 If its the same as fitting mk3 mondeo calipers on then you will need to drill the hub out to 12mm IIRC. You will also have to have a minimum of 16inch wheels otherwise you wont have the clearance Link to comment Share on other sites More sharing options...
TIL13R Posted November 5, 2010 Author Share Posted November 5, 2010 If its the same as fitting mk3 mondeo calipers on then you will need to drill the hub out to 12mm IIRC. You will also have to have a minimum of 16inch wheels otherwise you wont have the clearance Got that covered i got 17's to go on... Just didnt know if it was all the same....?? Link to comment Share on other sites More sharing options...
waynegc123 Posted November 5, 2010 Share Posted November 5, 2010 Jip and the washers for the banjo bolt clicky Link to comment Share on other sites More sharing options...
SLEEMAN Posted November 5, 2010 Share Posted November 5, 2010 i wouldn't put washers on the banjo, change the hoses to mondeo mk1. if you want a hand mate let me know as i'm down the road. Link to comment Share on other sites More sharing options...
hicksy Posted November 5, 2010 Share Posted November 5, 2010 i wouldn't put washers on the banjo, change the hoses to mondeo mk1. if you want a hand mate let me know as i'm down the road. Thats exactly what i did, i didnt remember that bit tho i did it soo long ago :L Link to comment Share on other sites More sharing options...
TIL13R Posted November 6, 2010 Author Share Posted November 6, 2010 (edited) i wouldn't put washers on the banjo, change the hoses to mondeo mk1. if you want a hand mate let me know as i'm down the road. Thanks for the offer mate il keep it in mind...!! Does the mk1 Mondeo have any braided lines for them.. as might aswel upgrade those too...! Edited November 6, 2010 by TIL13R Link to comment Share on other sites More sharing options...
SLEEMAN Posted November 6, 2010 Share Posted November 6, 2010 just ask the guys at goodridge they should be able to sort you out mate! Link to comment Share on other sites More sharing options...
skydivebaz Posted November 14, 2010 Share Posted November 14, 2010 Would be much better getting a set of earls hoses as you chose the length and fitments at 15 quid each and colour. Link to comment Share on other sites More sharing options...
