Jordan99940 Posted November 11, 2010 Share Posted November 11, 2010 Hey guys well last night went to go use my car the ol' windscreen had iced up, so I went to put the ol' heated front screen button on and i pushed it and the light literally came on for a split second not even half a second and then went of and everytime i went to push it after that nothing happened so my question is. has any body else had this problem and does any body know the rectification. cheers guys Jordan Link to comment Share on other sites More sharing options...
POSTIE Posted November 12, 2010 Share Posted November 12, 2010 yea had this problem turned out to be the relay had got damaged its located behind the battery worth checking its connected properly and all the contacts are good check the fuse as well as it might have blown after u put it on hope this helps a bit Link to comment Share on other sites More sharing options...
Ryoishikawa Posted November 12, 2010 Share Posted November 12, 2010 Check the fuses by the foot well and battery side . You the button may have died like mine did Link to comment Share on other sites More sharing options...
Jordan99940 Posted November 12, 2010 Author Share Posted November 12, 2010 will do cheers guys Link to comment Share on other sites More sharing options...
