16Vrhys Posted November 15, 2010 Share Posted November 15, 2010 have asked before and got some advise to check with wd40/ carb cleaner etc tried giving that all ago , but the revs did not change or any thing like that , but deffinatly can hear air leak when switch engine off , Link to comment Share on other sites More sharing options...
etrebus Posted November 15, 2010 Share Posted November 15, 2010 have asked before and got some advise to check with wd40/ carb cleaner etc tried giving that all ago , but the revs did not change or any thing like that , but deffinatly can hear air leak when switch engine off , does it run ok ? Link to comment Share on other sites More sharing options...
16Vrhys Posted November 15, 2010 Author Share Posted November 15, 2010 apart from idels and revs when it wants to not all the time which makes me think ICV but yea runs fine engine wise Link to comment Share on other sites More sharing options...
dan1.8si Posted November 15, 2010 Share Posted November 15, 2010 Think mine has a air leak too. but it mine runs like a bag off poo. have a look at the psv valve mate thats what im looking at next as ive tryed every thing else. Link to comment Share on other sites More sharing options...
16Vrhys Posted November 15, 2010 Author Share Posted November 15, 2010 psv? Link to comment Share on other sites More sharing options...
SteveB Posted November 16, 2010 Share Posted November 16, 2010 psv? pcv - positive crankcase ventilation. The little valve in the side of the block that vents the crankcase fumes back to the inlet manifold when conditions are right. Link to comment Share on other sites More sharing options...
16Vrhys Posted November 16, 2010 Author Share Posted November 16, 2010 where abouts is that like where am i looking from , obiously the cranks at the bottom but is it behind all the water pump pullies etc or some where else just for a better idea. Link to comment Share on other sites More sharing options...
SteveB Posted November 16, 2010 Share Posted November 16, 2010 where abouts is that like where am i looking from , obiously the cranks at the bottom but is it behind all the water pump pullies etc or some where else just for a better idea. Follow the pipe that comes from the intake manifold round to the front of the engine. The valve is on the end pushed into the block. It is either on the gearbox end of the block near to where the thermostat housing is, or it's on the oil separator behind the exhaust manifold. Link to comment Share on other sites More sharing options...
