nozaroc0 Posted November 21, 2010 Share Posted November 21, 2010 i have the 2.0 zetec in my car but it is running lean. i have been told that this can be cured by fitting a fuel pressure regulator, altho i have no idea which one to get or how to set them up as they are all messured in psi or bar and i wouldnt know how much or little to adjust by. anyone know anything that might help me? Link to comment Share on other sites More sharing options...
Stu Posted November 21, 2010 Share Posted November 21, 2010 If you're running the correct ECU, injectors and MAF sensor for the 2L engine then it shouldn't be running lean. This would point towards a problem that should be resolved rather than hacked by upping the fuel pressure (which isn't the solution). Link to comment Share on other sites More sharing options...
nozaroc0 Posted November 22, 2010 Author Share Posted November 22, 2010 If you're running the correct ECU, injectors and MAF sensor for the 2L engine then it shouldn't be running lean. This would point towards a problem that should be resolved rather than hacked by upping the fuel pressure (which isn't the solution). well this is where i get a little confused as i have modifications to the engine. it is a 2.0l block with rs1800 head with fast road cams (designed for the 2.0l) 2.0l fuel rail and injectors and the HO stamped inlet manifold, full exhaust inc 4-2-1 manifold. at rolling road at fordfair i was told it was running too lean as it was only 140bhp. but with the mods shud be closer to 150-155. so i suppose i shud probably need a re-map/chip before anything else, but i am told as a temporary measure a fpr is the answer. altho i have only been up an hour so none of the above could make any sence to anyone else.. Link to comment Share on other sites More sharing options...
Stu Posted November 22, 2010 Share Posted November 22, 2010 You haven't said which ECU you're using. Link to comment Share on other sites More sharing options...
nozaroc0 Posted November 22, 2010 Author Share Posted November 22, 2010 its a 2.0l DESK ecu Link to comment Share on other sites More sharing options...
Stu Posted November 22, 2010 Share Posted November 22, 2010 And what MAF sensor? Link to comment Share on other sites More sharing options...
nozaroc0 Posted November 22, 2010 Author Share Posted November 22, 2010 again from the 2.0l Link to comment Share on other sites More sharing options...
Stu Posted November 22, 2010 Share Posted November 22, 2010 Alright. So how lean is it running? How did the rolling road operators decide it was running lean? Sticking a wideband sensor in the tailpipe is not an accurate way to measure it really. For the spec you detail above, i'd expect it to be no more than 140bhp, and perform generally worse than a standard 2L engine below 4500rpm. Link to comment Share on other sites More sharing options...
Ryoishikawa Posted November 22, 2010 Share Posted November 22, 2010 i would double check if the parts your using are from the same car as that helps stopping the lean problem.... only thing i can think of is why your running lean is your standard fuel regulator is faulty or your injectors are faulty and you need them checked/test Link to comment Share on other sites More sharing options...
nozaroc0 Posted November 22, 2010 Author Share Posted November 22, 2010 ok, i think i need to get to a tuner that knows wot they are doing then. anyone know of any tuners in or near cornwall? preferably some one thet specialises in fords?? Link to comment Share on other sites More sharing options...
JC Posted November 22, 2010 Share Posted November 22, 2010 I would get the injectors refurbed, I seen and had no end off running issues with poor injectors! Link to comment Share on other sites More sharing options...
nozaroc0 Posted November 29, 2010 Author Share Posted November 29, 2010 Alright. So how lean is it running? How did the rolling road operators decide it was running lean? Sticking a wideband sensor in the tailpipe is not an accurate way to measure it really. For the spec you detail above, i'd expect it to be no more than 140bhp, and perform generally worse than a standard 2L engine below 4500rpm. it does preform realy well i think, tickover is about 950/1000rpm. revs pic up well and has a sort of 'boost' at 3500/4000rpm. I would get the injectors refurbed, I seen and had no end off running issues with poor injectors!how does refurbing the injectors work then? is it possible to refurb them myself? or worth buying a set that have already been refurbed? Link to comment Share on other sites More sharing options...
