skydivebaz Posted November 21, 2010 Share Posted November 21, 2010 Can i jump in as stu has replied, managed to get my 2 liter fired up yesterday and yes running like a bag of spanners!!! Today done the ECU and still like a bag of spanners on DEEP Still need to do the throttle body and a maf. I did notice today that we took off the air intake and the engine was getting in more air and without the maf. but god its lean as hell popping and just about idle!! but exhaust super hot!!! All four cylinders are 9-10 bar and double checked timing! i hope the 2 liter throttle body will help just seems to be over fueling so much Link to comment Share on other sites More sharing options...
scottg17 Posted November 21, 2010 Share Posted November 21, 2010 i think you answered your own question..... 1.6/1.8 ECU running on a 2.0 engine, Fuelling incorrect for the 2.0 engine,2.0 ECU with the 1.8 TB MAF, again not designed for that ECU resulting in running like a rubbish bag Change the MAF, Throttle Body, Injectors and it should be good Link to comment Share on other sites More sharing options...
skydivebaz Posted November 21, 2010 Author Share Posted November 21, 2010 i think you answered your own question..... 1.6/1.8 ECU running on a 2.0 engine, Fuelling incorrect for the 2.0 engine,2.0 ECU with the 1.8 TB MAF, again not designed for that ECU resulting in running like a rubbish bag Change the MAF, Throttle Body, Injectors and it should be good Injectors are on. Just yes maf and throttle body, did wonder took off maf and the air intake started to run a bit better but Fcuk me lean and almost flames out the exhaust!!! had to take bumper off as it was melting round the tail pipe!! now thats Fcuking hot!!!!!!! running on deep though so smething is working and not pats!! ao if they can start it and steal it good luck!! Link to comment Share on other sites More sharing options...
Stu Posted November 22, 2010 Share Posted November 22, 2010 Throttle body won't change this behaviour. Link to comment Share on other sites More sharing options...
skydivebaz Posted November 22, 2010 Author Share Posted November 22, 2010 Throttle body won't change this behaviour. it was a 1.6 TB and maf and the maf is tiny as i noticed today! Link to comment Share on other sites More sharing options...
Stu Posted November 22, 2010 Share Posted November 22, 2010 There you go. Link to comment Share on other sites More sharing options...
skydivebaz Posted November 22, 2010 Author Share Posted November 22, 2010 There you go. im hoping the tiny 1.6 TB and maf is somewhat the problem as toke off the air intake last night and she even ticked over ish! Link to comment Share on other sites More sharing options...
Stu Posted November 22, 2010 Share Posted November 22, 2010 Running the wrong MAF will lead to running issues. I'm starting to feel like i'm stuck in a loop on this now. Link to comment Share on other sites More sharing options...
JC Posted November 22, 2010 Share Posted November 22, 2010 Probably means you need to change the induction to eg. 1.8 GTi, thats what I did, and mine runs sweet :-) Link to comment Share on other sites More sharing options...
skydivebaz Posted November 22, 2010 Author Share Posted November 22, 2010 Probably means you need to change the induction to eg. 1.8 GTi, thats what I did, and mine runs sweet :-) well 2 Ltr TB and maf is on after some mods well a good bit of engineering! it started and actually sounded like it was running properly then shot up to 4k on the rev clock and died Sort of got it ticking ove but still not right! Dam pain in the arsh........ Link to comment Share on other sites More sharing options...
JC Posted November 23, 2010 Share Posted November 23, 2010 what injectors are you running? have they been refurbed? Link to comment Share on other sites More sharing options...
sortedgti2.0 Posted November 23, 2010 Share Posted November 23, 2010 my old gti engine was burning oil, valve stem seals were shot. this made the exhaust very hot have you got all the wires pluged in the way they should be. also what is the coil pack and leads like? Link to comment Share on other sites More sharing options...
