A/C parts, dash, Ghia surround, intake sensor and pipe, wiring loom
onehotminute_191
basically what you can see in the pictures.
the A/C parts were all removed from working models a long time ago and havent been used since. they come with (i believe) just about everything you need apart from maybe 2 small bolts that go into the bottom rad backet to fix the a/c rad. they are rubber things that are cheap from fords. also you will need the A/C pulley belt. might not have the A/C switch for inside either but that'll be cheap from evo or a breakers. if you have a later model escort then your wiring loom is probably ok with all the extra plugs but if not theres one supplied.
parts consist of 2x a/c pumps, 2x bottles, 1x pump/alternator mount with idle pulley, 1x fan (i think this is different from the standard one because of an extra plug for the a/c but its there anyway), 1x a/c radiator, 1x bottom mount for the radiators (you will already have this anyway), 2x a/c fan blowers, 1x fan control for inside the car, 1x 97AG wiring loom, lots of pipes!
http://www.evo-host.co.uk/getimg/25771.jpg
http://www.evo-host.co.uk/getimg/25772.jpg
Hoping for around £75 for all this but will consider offers. postage can be arrange but pickup is preferable due to the size and weight and awkwardness of all of it.
Ghia dash surround £10 posted
http://www.evo-host.co.uk/getimg/25773.jpg
standard dash that need a clean £15 posted
http://www.evo-host.co.uk/getimg/25774.jpg
air intake pipe with a sensor. unknown condition. £6 posted
http://www.evo-host.co.uk/getimg/25775.jpg
all items are located in Upminster, Essex and i have paypal.
cheers
