JC Posted January 3, 2011 Share Posted January 3, 2011 so im now buying v6 mondeo calipers, what disks do i need? will they fit under rs2k alloys? IIRC the RS2000 alloys are too small to fit, unless you trim the calliper, Escort cossy discs with Mondeo v6 calipers Link to comment Share on other sites More sharing options...
massivewangers Posted January 3, 2011 Share Posted January 3, 2011 You can get them to fit under RS2k wheels, but I think you have to grind the caliper and run a spacer I believe. Even then it's close. I've seen a picture on here of them fitted. They'll fit under most 15" wheels though, I've had them fitted under 15s without issue. I'd be tempted to fit 300mm ones myself. They'll go under certain 15" rims, I've seen them behind Fiesta Zetec-S 15s with a bit of caliper grinding. I'd avoid the RS2000 brakes for certain; they're pretty crap IMO. Link to comment Share on other sites More sharing options...
kizza9989 Posted January 3, 2011 Author Share Posted January 3, 2011 so to fit the calipers i need to grind them? if not what brake upgrade can i get to fit without grinding? Link to comment Share on other sites More sharing options...
massivewangers Posted January 3, 2011 Share Posted January 3, 2011 The RS2000 brakes are the biggest that will fit under the standard MK6 RS2000 wheels without modification, but I really wouldn't bother, I found them really disappointing. I can't see the point in forking out for the upgrade parts for a pretty poor braking set up. GTI wheels can be had cheap, even the 16" Mondeo ones are cheap, and then you could have the 300mm brakes, which are the best budget upgrade by far! Link to comment Share on other sites More sharing options...
bronze4door Posted January 5, 2011 Share Posted January 5, 2011 i've just done the mondeo V6 brakes on my car and was planning on fitting my RS wheels, going off some of this info you lot are saying they will now not fit over the caliper Link to comment Share on other sites More sharing options...
JC Posted January 5, 2011 Share Posted January 5, 2011 i've just done the mondeo V6 brakes on my car and was planning on fitting my RS wheels, going off some of this info you lot are saying they will now not fit over the caliper Let us know how you get on as I will also being doing this conversion.... Link to comment Share on other sites More sharing options...
bronze4door Posted January 5, 2011 Share Posted January 5, 2011 i've just done the mondeo V6 brakes on my car and was planning on fitting my RS wheels, going off some of this info you lot are saying they will now not fit over the caliper Let us know how you get on as I will also being doing this conversion.... the calipers are on just need bleeding but i have not tried to fit my wheels to it yet, my friend who is a mechaninc and runs a sierra xr4x4 which has 15's on says these brakes are the same as what is on his car i'll give it ago tomorrow but my brakes came off an escort in the scrappers so had everything i needed to fit em but i dont know what wheels it was running Link to comment Share on other sites More sharing options...
ScORTED Posted January 5, 2011 Share Posted January 5, 2011 http://www.escortevolution.co.uk/forums/in...c=94686&hl= http://i38.photobucket.com/albums/e105/escortstreetracer/R453_WHK/DSCF0006.jpg pretty sure his sierra will have 260mm front brakes as they don't fit straight on, 7mm spacers and a bit of caliper shaving will get them on as per the above pic I have done this Link to comment Share on other sites More sharing options...
bronze4door Posted January 6, 2011 Share Posted January 6, 2011 so i guess i have shot myself in the foot a little bit then and now will need some different wheels for it i'll see what they dont fit like in the morning then report my findings back Link to comment Share on other sites More sharing options...
ScORTED Posted January 6, 2011 Share Posted January 6, 2011 its a combination of the offset and the dish... it can be done though, i first though a few mm shaved off the face and 5mm spacers would do it and it just did but i added another 2mm of spacing to give expansion roomlooks the rubbish though with the brakes filling the wheels! Link to comment Share on other sites More sharing options...
bronze4door Posted January 6, 2011 Share Posted January 6, 2011 i tried em this morning and the wheels definatley wont fit, i have got some spacers knocking round somwhere so i will dig them out and see what i can do Link to comment Share on other sites More sharing options...
bronze4door Posted January 9, 2011 Share Posted January 9, 2011 just a quick update, the RS wheels dont fit but the christmas tree style triangle things off my estate fit on without a problem, no caliper shaving was required Link to comment Share on other sites More sharing options...
JC Posted January 9, 2011 Share Posted January 9, 2011 Which RS alloys? I'm having Danzetec make me some spacers, so cossie discs and v6 calipers should fit perfectly Link to comment Share on other sites More sharing options...
massivewangers Posted January 9, 2011 Share Posted January 9, 2011 Which RS alloys? I'm having Danzetec make me some spacers, so cossie discs and v6 calipers should fit perfectly MK6 RS2000 I believe Link to comment Share on other sites More sharing options...
bronze4door Posted January 11, 2011 Share Posted January 11, 2011 yeah i meant the RS 2000 alloys as that is what my car had but it now has the triangle multi spokes so i need to get another set of these or change my tyres ready for the next track day Link to comment Share on other sites More sharing options...
