gazeebo Posted December 12, 2010 Share Posted December 12, 2010 Hi all.I've just bought a pair of new rear brake discs and pads for my Mk5 Kreg Escort XR3I.When I've got home and unwrapped the discs I've noticed that there are only 4 holes on the disc,obviously for the wheel studs/nuts.On looking in the Haynes manual regarding changing the discs it states that you should undo the torx screw to remove the disc from the hub.Will I have to drill a hole in each of the new discs or have I been giving the wrong ones?? I'll probably end up getting it done professionally as I'm having the front ones done as well.(Safety and all that).Cheers,Gaz. Link to comment Share on other sites More sharing options...
DaweV6 Posted December 12, 2010 Share Posted December 12, 2010 Hi all.I've just bought a pair of new rear brake discs and pads for my Mk5 Kreg Escort XR3I.When I've got home and unwrapped the discs I've noticed that there are only 4 holes on the disc,obviously for the wheel studs/nuts.On looking in the Haynes manual regarding changing the discs it states that you should undo the torx screw to remove the disc from the hub.Will I have to drill a hole in each of the new discs or have I been giving the wrong ones?? I'll probably end up getting it done professionally as I'm having the front ones done as well.(Safety and all that).Cheers,Gaz. Haynes is lying. There are no holes for torxes. Don't need them, brake shoes are holding the disc pretty firmly. It's a pretty straightforward swapover, unless the braking system is ancient and shoes won't let go of discs, in which case after some struggle (and hammer) the possibly rusty retaining clips might snap. But that's about the worst case scenario. Link to comment Share on other sites More sharing options...
ldnvan Posted December 16, 2010 Share Posted December 16, 2010 ive got the opposite, ive got an escort van and the discs have a hole for the bolt, and no thread on the hub, but the calipper holds the disc where it is, mine stops fine. Link to comment Share on other sites More sharing options...
p4u1 Posted December 17, 2010 Share Posted December 17, 2010 (edited) its just to hold the disk to the hub no big deal if its not there not all cars have them, in fact they can be a bar stool to undo if theyve rusted lol Edited December 17, 2010 by p4u1 Link to comment Share on other sites More sharing options...
gazeebo Posted December 17, 2010 Author Share Posted December 17, 2010 Many thanks for the replies.I've been given a quote of £120 to replace the front and rear discs and pads.Is that a reasonable price or should I be looking elsewhere? I could try it myself but was told that replacing the rear's was harder than the front's!! On a scale of 1 to 10 how hard is it to replace the whole job lot? Bear in mind that my overall mechanical competence is amateurish.Cheers,Gaz. Link to comment Share on other sites More sharing options...
Danzetec Posted December 19, 2010 Share Posted December 19, 2010 Its not too hard normally but get a couple more quotes and compare prices. If you aren't happy to complete the job yourself then get a garage to do it, especially when it comes to brakes Link to comment Share on other sites More sharing options...
