ginger9991 Posted December 14, 2010 Share Posted December 14, 2010 Hi guys! i lost a headlight last week and when i was in the car today the other one went. I replaced both the bulbs (both the ones i took out were fine!) but it still doesnt work! I have checked the fuses and they are fine! any ideas? All other lights and everything else appears to work fine! Link to comment Share on other sites More sharing options...
shawdreamer Posted December 14, 2010 Share Posted December 14, 2010 Hi guys! i lost a headlight last week and when i was in the car today the other one went. I replaced both the bulbs (both the ones i took out were fine!) but it still doesnt work! I have checked the fuses and they are fine! any ideas? All other lights and everything else appears to work fine! are you saying that the second headlight went while the first was still out? if so I say overload or voltage surge took the other out (iirc the escort headlight circuit is a inline affair so when one bulb go's 9 out of 10 times the second will go shortly afterwards) Link to comment Share on other sites More sharing options...
ginger9991 Posted December 14, 2010 Author Share Posted December 14, 2010 Hi guys! i lost a headlight last week and when i was in the car today the other one went. I replaced both the bulbs (both the ones i took out were fine!) but it still doesnt work! I have checked the fuses and they are fine! any ideas? All other lights and everything else appears to work fine! are you saying that the second headlight went while the first was still out? if so I say overload or voltage surge took the other out (iirc the escort headlight circuit is a inline affair so when one bulb go's 9 out of 10 times the second will go shortly afterwards) I think its the switch on the stalks BECAUSE! i have replaced the lights and they are not working HOWEVER when i put full beams on they work! anyone agree? Link to comment Share on other sites More sharing options...
duffa Posted December 15, 2010 Share Posted December 15, 2010 was gonna say..try the stalks...i once had the same problem ..had to drive home with full beam on Link to comment Share on other sites More sharing options...
