Scort_CVH Posted December 26, 2010 Share Posted December 26, 2010 Alright lads I realised I dont have a project thread up on this, so here goes: Im going to need loads of help as this is my first ever big project. Right so the base for the project: http://i64.photobucket.com/albums/h183/SUBARU_2006/SDC11526.jpg RecarosRS2k bodykitWill go back to its RS2k wheelsRS2k brakes (rear axle to be fitted)Viper alarmWhite dialsLaguna splitterLowered 40mmMagnex exhaustK&N cone filter And now for the interesting part http://i64.photobucket.com/albums/h183/SUBARU_2006/Built/FRSTENGINE.jpg Fiesta RST engine on 74k miles, T3 conversion, piper cam, XR2i (OFAB) loom £250Got a standard S1 cooler to check all is well before i go nuts £15 As you can see the pipes etc arnt there so ill need help with where to put the new ones etc please This is going to be a slow project as it gets fitted between uni and work (4.5 days a week) but all updates will have work done and not just chat Ok so the start:http://i64.photobucket.com/albums/h183/SUBARU_2006/Built/photo7.jpg All parked up with drivers side driveshaft already removed http://i64.photobucket.com/albums/h183/SUBARU_2006/Built/photo6.jpg Time to start labeling as its my first engine swap OO radiators gone http://i64.photobucket.com/albums/h183/SUBARU_2006/Built/photo5.jpg Random parts find (there not in the garage to get damaged lol) http://i64.photobucket.com/albums/h183/SUBARU_2006/SDC11522.jpg Morettes with 2 spare lenses and a ford strut brace £85Scorpion cat back £15Avo coilovers £80Laguna splitter £2 Then I got bored, which is dangerous http://i64.photobucket.com/albums/h183/SUBARU_2006/Built/photo.jpg And because i was by myself i had to use the best tools http://i64.photobucket.com/albums/h183/SUBARU_2006/Built/photo2.jpg Also got an rs rear beam which will get a refurb and a twin arb set up (when i find 2 arbs lol) http://i64.photobucket.com/albums/h183/SUBARU_2006/IMG_0003.jpg And now for more coursework lol Link to comment Share on other sites More sharing options...
Jordan99940 Posted December 26, 2010 Share Posted December 26, 2010 Wow good luck with this i am very interested to see how this progresses Link to comment Share on other sites More sharing options...
tezmanian devil Posted December 26, 2010 Share Posted December 26, 2010 Good stuff mate, good luck with it all, it always seems harder than it actually is.The pipe work from you cvh would fit, just need the top rad hose from and erst which has the turbo cooler pipe coming off of it if your using water cooling for the turbo that is? With my old on I just cut the top header tank pipe that goes to top of thermastat housing and connected that to the turbo cooler pipes.. Link to comment Share on other sites More sharing options...
JC Posted December 26, 2010 Share Posted December 26, 2010 Good luck, i wouldn't bother with the rs2k brakes on the front, if you have big wheels, go for a Mk3 caliper and st170 disc Link to comment Share on other sites More sharing options...
shifty Posted December 26, 2010 Share Posted December 26, 2010 Nice project. Good luck with it! Link to comment Share on other sites More sharing options...
Scort_CVH Posted December 26, 2010 Author Share Posted December 26, 2010 Wow good luck with this i am very interested to see how this progresses Cheers mate, never been near a turbo engine before so its all new lol Good stuff mate, good luck with it all, it always seems harder than it actually is.The pipe work from you cvh would fit, just need the top rad hose from and erst which has the turbo cooler pipe coming off of it if your using water cooling for the turbo that is? With my old on I just cut the top header tank pipe that goes to top of thermastat housing and connected that to the turbo cooler pipes.. Thanks mate , right ill need to look into this, once ive got the 1.4 stripped down and moved ill get the rst into the bay and take some pics and ill bug you about it as like i said first time near a turbo engine and its all new Good luck, i wouldn't bother with the rs2k brakes on the front, if you have big wheels, go for a Mk3 caliper and st170 disc The RS fronts are already on it from when it was a 1.4. however i do have some mk3 callipers in the garage aswell Link to comment Share on other sites More sharing options...
Stu Posted December 26, 2010 Share Posted December 26, 2010 Where do you intend to sit the ECU? A standard OFAB loom wants to mount the ECU in the firewall, not house it inside the car like an Escort/Mondeo loom. I think if I was doing a conversion like this, i'd modify an Escort loom to suit the application as that'll most likely end up more reliable than extending a Fiesta loom. Also, intercooler, you may as well just go with a reasonable intercooler in the first place. Mk6 Escort has a fair bit of room, some of the cheapie ebay £99 intercoolers will go in well.. Std intercooler is barely good enough for standard power. Link to comment Share on other sites More sharing options...
DaweV6 Posted December 26, 2010 Share Posted December 26, 2010 Morettes with 2 spare lenses and a ford strut brace £85Scorpion cat back £15Avo coilovers £80Laguna splitter £2 Bargains ! Scrappy ? Rear beam - it's a MK5 one, right ? Can't see very well from those pics. I was wondering - instead of using 2 arb's, wouldn't be easier to box it in and seam weld it ? To achieve a stronger one, more than Mk6... Bit like this - http://img694.imageshack.us/img694/88/dsc02006zc77.th.jpg Link to comment Share on other sites More sharing options...
Scort_CVH Posted December 26, 2010 Author Share Posted December 26, 2010 Where do you intend to sit the ECU? A standard OFAB loom wants to mount the ECU in the firewall, not house it inside the car like an Escort/Mondeo loom. I think if I was doing a conversion like this, i'd modify an Escort loom to suit the application as that'll most likely end up more reliable than extending a Fiesta loom. Also, intercooler, you may as well just go with a reasonable intercooler in the first place. Mk6 Escort has a fair bit of room, some of the cheapie ebay £99 intercoolers will go in well.. Std intercooler is barely good enough for standard power. Ive been looking into the ecu location possibilites and you have mentioned the two i found, however there doesnt seem to be any written articles on changing my loom to OFAB as most people seem to change the fiesta XR2i loom. I think ill go with a bigger cooler once ive got it running, but as my budget is small i want to get management and turbo spot on as they seem to be the most expensive. Any input you have is much appreciated, after all the sole reason for this project is so i can learn from it Morettes with 2 spare lenses and a ford strut brace £85Scorpion cat back £15Avo coilovers £80Laguna splitter £2 Bargains ! Scrappy ? Rear beam - it's a MK5 one, right ? Can't see very well from those pics. I was wondering - instead of using 2 arb's, wouldn't be easier to box it in and seam weld it ? To achieve a stronger one, more than Mk6... Bit like this - http://img694.imageshack.us/img694/88/dsc02006zc77.th.jpg Scrappy for the exhaust and splitter, the rest where from Reid that was on here. the engine was also Reids out of his turbo project however the lock up burnt to the ground so he sold the engine on Yeah its mk5, that could be another option that i'll need to look into. However id prefer something slightly more adjustable hmmmm Thanks for the ideas lads much appreciated as this is all new to me and im terrified of wiring but im going to attempt to sort that Link to comment Share on other sites More sharing options...
Stu Posted December 26, 2010 Share Posted December 26, 2010 I'm not sure the beam you've got is an RS2K one.. I assume it didn't come with a bar? Link to comment Share on other sites More sharing options...
Scort_CVH Posted December 26, 2010 Author Share Posted December 26, 2010 I'm not sure the beam you've got is an RS2K one.. I assume it didn't come with a bar?Didn't come with a bar but has a couple of the brackets for one :S same as my beam off bluiz old si. I don't mind making up brackets so I just need to see if people think it would be necessary Link to comment Share on other sites More sharing options...
tezmanian devil Posted December 26, 2010 Share Posted December 26, 2010 The brackets for the arb are stil available new from ford I'm pretty sure most of the zetec coolant hoses fit a cvh aswel, just needto tee in a couple of extra hoses to go down to the oil cooler. Link to comment Share on other sites More sharing options...
Scort_CVH Posted December 27, 2010 Author Share Posted December 27, 2010 The brackets for the arb are stil available new from ford I'm pretty sure most of the zetec coolant hoses fit a cvh aswel, just needto tee in a couple of extra hoses to go down to the oil cooler. I might try the ford part place, tho i was hoping to make up a twin mount bracket oil coolers are for rich people jk Link to comment Share on other sites More sharing options...
Stu Posted December 27, 2010 Share Posted December 27, 2010 I think tez was referring to the OEM water/oil heat exchanger (modine), not some fancy unnecessary oil cooler. Link to comment Share on other sites More sharing options...
chris179 Posted December 27, 2010 Share Posted December 27, 2010 I've got a 1400CVH 3door escort with big end damage, was going to do a turbo conversion on it but weather I'll get round to it or not is another thing lol. What you doing with the old CVH? It run ok? Link to comment Share on other sites More sharing options...
