friff Posted December 29, 2010 Share Posted December 29, 2010 been tols that the rear stub axel off a focus will bolt streight onto my axel on scrot if this is true was goin to put st170 ones on and have 280mm all round? Link to comment Share on other sites More sharing options...
RO55 Posted December 29, 2010 Share Posted December 29, 2010 They only fit the MK6 beam. 3 Options for you. Focus 2.0 16v - / - ST150 = 255mm +25 offset ST170 = 280mm +25 offset Focus RS = 280mm +33 offset. All the above share the same caliper so you require a Puma 1.7 16v Front Hose. Link to comment Share on other sites More sharing options...
friff Posted December 29, 2010 Author Share Posted December 29, 2010 They only fit the MK6 beam. 3 Options for you. Focus 2.0 16v - / - ST150 = 255mm +25 offset ST170 = 280mm +25 offset Focus RS = 280mm +33 offset. All the above share the same caliper so you require a Puma 1.7 16v Front Hose. yeah its on a mk6, so your sayin it will work as long as i use puma 1.7 front pipes??? Link to comment Share on other sites More sharing options...
RO55 Posted December 29, 2010 Share Posted December 29, 2010 They only fit the MK6 beam. 3 Options for you. Focus 2.0 16v - / - ST150 = 255mm +25 offset ST170 = 280mm +25 offset Focus RS = 280mm +33 offset. All the above share the same caliper so you require a Puma 1.7 16v Front Hose. yeah its on a mk6, so your sayin it will work as long as i use puma 1.7 front pipes??? Yeah but I noticed you have an Escort GTi?? It wont work with the ABS unless tou machine the hubs .. Get the Focus 2.0 16v set up ... £20 a side from a scrappy .. Link to comment Share on other sites More sharing options...
friff Posted December 29, 2010 Author Share Posted December 29, 2010 They only fit the MK6 beam. 3 Options for you. Focus 2.0 16v - / - ST150 = 255mm +25 offset ST170 = 280mm +25 offset Focus RS = 280mm +33 offset. All the above share the same caliper so you require a Puma 1.7 16v Front Hose. yeah its on a mk6, so your sayin it will work as long as i use puma 1.7 front pipes??? Yeah but I noticed you have an Escort GTi?? It wont work with the ABS unless tou machine the hubs .. Get the Focus 2.0 16v set up ... £20 a side from a scrappy .. nice one thanx for info pal u been a great help Link to comment Share on other sites More sharing options...
projectrs2k Posted December 31, 2010 Share Posted December 31, 2010 They only fit the MK6 beam. 3 Options for you. Focus 2.0 16v - / - ST150 = 255mm +25 offset ST170 = 280mm +25 offset Focus RS = 280mm +33 offset. All the above share the same caliper so you require a Puma 1.7 16v Front Hose. yeah its on a mk6, so your sayin it will work as long as i use puma 1.7 front pipes??? Yeah but I noticed you have an Escort GTi?? It wont work with the ABS unless tou machine the hubs .. Get the Focus 2.0 16v set up ... £20 a side from a scrappy .. nice one thanx for info pal u been a great help or you can by mine for £120 with discs pads that are 2month old handbrake cable and as for hoses the focus ones screw straight into the escort ones Link to comment Share on other sites More sharing options...
