Naylor2006 Posted December 30, 2010 Share Posted December 30, 2010 Not so long ago i notcied a horrible fuuurrrrururururrrrururbub noise from my power steering, checked the fluid and it barely had any. Topped up, problem solved until around 9 days later when it was low again, so i shoved in some of that halfords leak fixing fluid which im not sure to be honest if it did anything, im still filling up every 7-9 days. Couple of things to mention is that at idle when the car is warm you can smell the fluid im sure either burning away or leaking onto something hot. I thought this could be the motor burning the fluid off which is why it smells. Either way I cant seem to find a leak and I dont want to have Mr Garage Mechanic charge 3000 pounds for a new motor or to find the leak if anyone on here can help me in my investigation. Many thanks guys Link to comment Share on other sites More sharing options...
etrebus Posted December 30, 2010 Share Posted December 30, 2010 Not so long ago i notcied a horrible fuuurrrrururururrrrururbub noise from my power steering, checked the fluid and it barely had any. Topped up, problem solved until around 9 days later when it was low again, so i shoved in some of that halfords leak fixing fluid which im not sure to be honest if it did anything, im still filling up every 7-9 days. Couple of things to mention is that at idle when the car is warm you can smell the fluid im sure either burning away or leaking onto something hot. I thought this could be the motor burning the fluid off which is why it smells. Either way I cant seem to find a leak and I dont want to have Mr Garage Mechanic charge 3000 pounds for a new motor or to find the leak if anyone on here can help me in my investigation. Many thanks guysmust be leaking some where get it up in the air and have a good look at the rack sounds like its leaking on the exhaust Link to comment Share on other sites More sharing options...
Jordan99940 Posted December 30, 2010 Share Posted December 30, 2010 if you have the power steering cooling coil on the front of your car check that for corrosion my one wore through http://www.evo-host.co.uk/getimg/25581.jpg Link to comment Share on other sites More sharing options...
Naylor2006 Posted December 31, 2010 Author Share Posted December 31, 2010 Thanks guys. What's weird is there is never any fluid on the floor for me to find. I'm sure it's burning away, just have to have a better look. I don't think I have the cooling coil, all my ps gear is on the left, your pic shows the right hand side and I'm pretty sure I've followed the pipes. Confirmed that I can only smell it once the car is warm and stationary. Link to comment Share on other sites More sharing options...
Naylor2006 Posted February 4, 2011 Author Share Posted February 4, 2011 Thanks guys. What's weird is there is never any fluid on the floor for me to find. I'm sure it's burning away, just have to have a better look. I don't think I have the cooling coil, all my ps gear is on the left, your pic shows the right hand side and I'm pretty sure I've followed the pipes. Confirmed that I can only smell it once the car is warm and stationary. DOH! The power steering leak is coming from the rack its self , gonna be expensive no doubt Link to comment Share on other sites More sharing options...
