Cabtastic Posted January 4, 2011 Share Posted January 4, 2011 can any1 tell me what pins on the pic below are positive and negitive...this is a mk4 fiesta central locking motor. many thanksDave. http://img.photobucket.com/albums/v101/xratedcab/motor.jpg Link to comment Share on other sites More sharing options...
Craig855S Posted January 4, 2011 Share Posted January 4, 2011 mk4 fiesta haynes will tell you Link to comment Share on other sites More sharing options...
shawdreamer Posted January 4, 2011 Share Posted January 4, 2011 mk4 fiesta haynes will tell you aslong as you have atleast the plug for it with the smallest ends of wires still connected, so you can ID colour codes and pin connections. Link to comment Share on other sites More sharing options...
Cabtastic Posted January 4, 2011 Author Share Posted January 4, 2011 mk4 fiesta haynes will tell you yes i know. but not spending £15 on a book i need for 2 minuites. .. thanks anyways. mk4 fiesta haynes will tell you aslong as you have atleast the plug for it with the smallest ends of wires still connected, so you can ID colour codes and pin connections. no plug, unless i go buy 1at a scrappy. .... just putting central locking on 1 door for my my gfs car... just using the motor and a central locking kit.... as it seems impossible with just poppers from a universal kit..... so useing this motor with positive n negitive feed from the universal kit module.. Thanks guys. Link to comment Share on other sites More sharing options...
shawdreamer Posted January 4, 2011 Share Posted January 4, 2011 mk4 fiesta haynes will tell you yes i know. but not spending £15 on a book i need for 2 minuites. .. thanks anyways. mk4 fiesta haynes will tell you aslong as you have atleast the plug for it with the smallest ends of wires still connected, so you can ID colour codes and pin connections. no plug, unless i go buy 1at a scrappy. .... just putting central locking on 1 door for my my gfs car... just using the motor and a central locking kit.... as it seems impossible with just poppers from a universal kit..... so useing this motor with positive n negitive feed from the universal kit module.. Thanks guys. universal popper aint as difficult as it first appears, theres a couple of points on the locking mechanism were you can hook the supplied roods onto. however if you wish to use the OEM stuff then you need only get a look at a wired unit in the scrappers, then make note of wire colours and positions. after that someone with a haynes should be able to give you exact wiring instructions. Link to comment Share on other sites More sharing options...
Cabtastic Posted January 4, 2011 Author Share Posted January 4, 2011 ok ill do that.. thanks peeps.. Link to comment Share on other sites More sharing options...
