RobMk6 Posted January 6, 2011 Author Share Posted January 6, 2011 I know I'll need the adaptor for the water temp, thats the priority one as since the white scort paranoia has set in is yours mounted in the top hose? what diameter casing did you get? and the oil one uses a sandwich plate between the filter? Link to comment Share on other sites More sharing options...
JC Posted January 6, 2011 Share Posted January 6, 2011 Knew there was something I forgot to add.... it was a 36mm, in the top of the rad hose, its jst under the induction so hidden away. its a very tight fit, but you want it tight I got my stuff here: linky cheapest I found for the one i decided I wanted yeah uses a sandwich plate, you can add oil pressure to the same bit too I have both oil and water, as my temp guage doesn't work and want to keep a close eye on the temps esp on the track and with my engine! Link to comment Share on other sites More sharing options...
RobMk6 Posted January 6, 2011 Author Share Posted January 6, 2011 thats the reason I want is I've a feeling this ones a keeper and will eventually see some nice power gains, but atm i've a feeling the fitting of the plasma dials may have thrown the temp sensor a bit as it reads far too cold. Link to comment Share on other sites More sharing options...
RobMk6 Posted January 8, 2011 Author Share Posted January 8, 2011 Good start, ordered a water temp gauge and sender housing and what turned up this morning..... 2 rose joints... 90% of the time I order online, whether it be ebay or other, I get sent the wrong, or no items at all. Link to comment Share on other sites More sharing options...
