bad ass cossie Posted February 21, 2011 Share Posted February 21, 2011 Hi guys will cosworth offset fit a standered escort hub as the wheels are 8x18 (ET15)if not what is needed for them to fit cheers. Link to comment Share on other sites More sharing options...
Ahmotorsport Posted February 22, 2011 Share Posted February 22, 2011 They will physically bolt on but i don't think they will stay under your wing, pretty sure you'd need arches as standard escorts are about ET35-40. Link to comment Share on other sites More sharing options...
stoo2000 Posted February 22, 2011 Share Posted February 22, 2011 We've moved this topic into the correct section. Link to comment Share on other sites More sharing options...
HIGHTOWER Posted February 22, 2011 Share Posted February 22, 2011 They will physically bolt on but i don't think they will stay under your wing, pretty sure you'd need arches as standard escorts are about ET35-40. Correct! They would sit outside your wheel arch about 20mm and would rub like feck! Without wide arches and your old arches cut away, they will not fit! Link to comment Share on other sites More sharing options...
