What size are a standard MK6 escort front wheel Stud?
As having fitted spacers the nuts don't have quite enough length on the stud to lock up enough to my satifaction... hence the above question
thanks
12x1.5 i believe
I'd expect them to be longer than 12mm, as they pass through the hub which is probably 10mm by itself!
Sorry, i'm thinking nut sizes.
45mm iirc.
Edited by bongo
