Viper Posted March 20, 2011 Share Posted March 20, 2011 The rear passanger drum is locking after 180degrees of movment. any ideas. the car was sat for 5days if that helps.?? driving it about 30 yards did not un-jam like it usual would do. Link to comment Share on other sites More sharing options...
Redneck Posted March 21, 2011 Share Posted March 21, 2011 I had this when my the shoes in mine disintegrated, locked the drum solid as though the handbrake was on really tight. You can give it a good whack with a heavy hammer to try and loosen off whatever's jammed inside there but it's a drum off job really to see what's wrong unless you can see anything through the inspection plate (probably not). You can probably discount this if you've had new shoes in there anytime recently though... Link to comment Share on other sites More sharing options...
