scottie4444 Posted March 22, 2011 Share Posted March 22, 2011 hi peeps need some help needed a tyre so been and got one 205/ 50/ 16 now this is the problem when i brake something sounds to be catching and it some times does it when just driving along any ideas please Link to comment Share on other sites More sharing options...
scottie4444 Posted March 22, 2011 Author Share Posted March 22, 2011 any please i need help Link to comment Share on other sites More sharing options...
Scort_CVH Posted March 22, 2011 Share Posted March 22, 2011 is that tyre a different size to the one you had previously? theres so many things it could be. when you say driving along - as in cornering, straight lines, over bumps? Link to comment Share on other sites More sharing options...
scottie4444 Posted March 22, 2011 Author Share Posted March 22, 2011 is that tyre a different size to the one you had previously? theres so many things it could be. when you say driving along - as in cornering, straight lines, over bumps?yes it is the same size also when driving it in a straight line Link to comment Share on other sites More sharing options...
JC Posted March 22, 2011 Share Posted March 22, 2011 details about what car it is fitted to would help? Link to comment Share on other sites More sharing options...
scottie4444 Posted March 22, 2011 Author Share Posted March 22, 2011 it is 1997 escort saloon 1.8 zetec Link to comment Share on other sites More sharing options...
scottie4444 Posted March 22, 2011 Author Share Posted March 22, 2011 come on anyone some one must have an idea Link to comment Share on other sites More sharing options...
scottie4444 Posted March 23, 2011 Author Share Posted March 23, 2011 right found what the wheel is catching on its the arch but dont no why it is because they are the same size tyre on both sides Link to comment Share on other sites More sharing options...
scottie4444 Posted March 24, 2011 Author Share Posted March 24, 2011 right found what the wheel is catching on its the arch but dont no why it is because they are the same size tyre on both sides Link to comment Share on other sites More sharing options...
Scort_CVH Posted March 24, 2011 Share Posted March 24, 2011 Broken coil spring, fooked shock. Unless the arch liner is hanging off Link to comment Share on other sites More sharing options...
scottie4444 Posted March 24, 2011 Author Share Posted March 24, 2011 shock and spring are fine and them checked liner looks ok only thing i can think is the tyre as been stamped wrong and that it is not a 205/50/16 could that be poss Link to comment Share on other sites More sharing options...
Scort_CVH Posted March 24, 2011 Share Posted March 24, 2011 I've never seen it when I fitted tyres, only thing I can suggest is swapping the 2 front wheels and seeing uf it continues Link to comment Share on other sites More sharing options...
scottie4444 Posted March 24, 2011 Author Share Posted March 24, 2011 ok mate thank you Link to comment Share on other sites More sharing options...
Stu Posted March 24, 2011 Share Posted March 24, 2011 Same size doesn't mean same design. 205/50/16 is the wrong size on an Escort and is quite likely to rub with certain sidewall designs. Link to comment Share on other sites More sharing options...
scottie4444 Posted March 24, 2011 Author Share Posted March 24, 2011 ok been and had it swapped and its now stopped catching on arch still catching on iner arch on full lock but its always done that thanks for your help Link to comment Share on other sites More sharing options...
