timturbo Posted January 18, 2012 Share Posted January 18, 2012 (edited) ***LOCATED sanderstead surrey *** mk6 angel eye headlights £70 mk6 40mm lowering springs unknown brand have been sitting in garage for a while now £20 mk6 lexus style rear lights £20 Back up for grabs my series 2 full car breaking every part available quick sell wanted on most parts but please not ridiculous offers. Preferably would like running gear to be sold as one but willing to split everything individually. OFFERS WELCOME ON EVERYTHING AVAILABLE Engine head and block- low compression pistons, standard rods built 1500miles ago. stage 3 big valve head with newmans cam with solid lifters engine is capable of 270bhp £900 Exhaust manifold and t34 turbo with smaller exhaust housing for quicker spool up car used to boost at 3000rpm no play in the shaft reciept from turbo dynamics for £895. £550 EFI inlet powercoated silver with fuel rail pressure regulator etc £80 Cosworth throttle body with cosworth tps sensor iscv modified for the use of anti lag car does not need to run anti lag to be used £65 Green 803 £100 Level 8 ecu cossie management with 2wd loom, custom msd live map, anti lag cam sensor, crank sensor and triggers etc £750 AP racing 4 paddle clutch £175 Scorpion Exhaust 4inch backbox £120Scorpion Exhaust 4inch debaffled backbox £140 Series 2 dashboard x 2 one immaculate no marks £45, one in good condition has had 1 switch fitted for washer jets £40 Stage 1 gearbox £250 Series 2 standard gearbox £130 Pipercross cone air filter £40 Samco boost hoses £40 GRS intercooler £200 Pace double capacity intercooler £80 MFI metering unit excellent condition perfect working order £sold Ford racing gauges volts, boost, water temperature and oil pressure £60 each Standard original series 2 clocks with 90k £20 White lockwood clocks fully working order £20 Flocked centre console for handbrake surround £sold Flocked surround underneath the dash below the dash £sold Twins dash surround for one 52mm gauge mint condition £sold FORD RS mudflaps in blue brand £50 Field Motorsport oil breather/catch tank lovely item £45 OMP 350mm 90mm dish wheel lovely wheel £sold OMP 315mm or 300mm with 90mm dish lovely wheel £120 RS turbo boss £20 Isotto Steering wheel £30 Standard cosworth front brakes £100 Koni adjustables full set mint condition £200 Gaz coilovers brand new never fitted £400 2 Kenlowe slim fans £100Standard rad £30, standard rad with bent fins and broken mounts untested £15 Start Motor x2 £25 Flywheels £20 Driveshafts £25 Steering rack £20 TCA powdercoated gold £25 Rear lower arms powdercoated gold £30 Front anti roll bar standard s2 and gearbox cradle powdercoated gold £40 Laguna Splitter £30 Headlights in good condition no marks £30 Standard clear indicators £15 Standard Series 2 wheels immaculate condition £200 RL7 7 spoke alloy wheels 5 available £750 Shell SOLD Smoked rear tail lights £30 Interior front seats and back seats £150 good condition small wear to drivers bolster. Front door cars one usual wear £40 90 spec. Immaculate front door cards £80 Carpet £40 Mint headlining £40 Rear door cards £20 Parcel shelf £10 http://i146.photobucket.com/albums/r269/timturbo/untitled-1.jpg Edited January 18, 2012 by PeeWee Link to comment Share on other sites More sharing options...
Dyl Posted January 19, 2012 Share Posted January 19, 2012 ***LOCATED sanderstead surrey *** mk6 angel eye headlights £70 mk6 40mm lowering springs unknown brand have been sitting in garage for a while now £20 mk6 lexus style rear lights £20 Back up for grabs my series 2 full car breaking every part available quick sell wanted on most parts but please not ridiculous offers. Preferably would like running gear to be sold as one but willing to split everything individually. OFFERS WELCOME ON EVERYTHING AVAILABLE Engine head and block- low compression pistons, standard rods built 1500miles ago. stage 3 big valve head with newmans cam with solid lifters engine is capable of 270bhp £900 Exhaust manifold and t34 turbo with smaller exhaust housing for quicker spool up car used to boost at 3000rpm no play in the shaft reciept from turbo dynamics for £895. £550 EFI inlet powercoated silver with fuel rail pressure regulator etc £80 Cosworth throttle body with cosworth tps sensor iscv modified for the use of anti lag car does not need to run anti lag to be used £65 Green 803 £100 Level 8 ecu cossie management with 2wd loom, custom msd live map, anti lag cam sensor, crank sensor and triggers etc £750 AP racing 4 paddle clutch £175 Scorpion Exhaust 4inch backbox £120Scorpion Exhaust 4inch debaffled backbox £140 Series 2 dashboard x 2 one immaculate no marks £45, one in good condition has had 1 switch fitted for washer jets £40 Stage 1 gearbox £250 Series 2 standard gearbox £130 Pipercross cone air filter £40 Samco boost hoses £40 GRS intercooler £200 Pace double capacity intercooler £80 MFI metering unit excellent condition perfect working order £sold Ford racing gauges volts, boost, water temperature and oil pressure £60 each Standard original series 2 clocks with 90k £20 White lockwood clocks fully working order £20 Flocked centre console for handbrake surround £sold Flocked surround underneath the dash below the dash £sold Twins dash surround for one 52mm gauge mint condition £sold FORD RS mudflaps in blue brand £50 Field Motorsport oil breather/catch tank lovely item £45 OMP 350mm 90mm dish wheel lovely wheel £sold OMP 315mm or 300mm with 90mm dish lovely wheel £120 RS turbo boss £20 Isotto Steering wheel £30 Standard cosworth front brakes £100 Koni adjustables full set mint condition £200 Gaz coilovers brand new never fitted £400 2 Kenlowe slim fans £100Standard rad £30, standard rad with bent fins and broken mounts untested £15 Start Motor x2 £25 Flywheels £20 Driveshafts £25 Steering rack £20 TCA powdercoated gold £25 Rear lower arms powdercoated gold £30 Front anti roll bar standard s2 and gearbox cradle powdercoated gold £40 Laguna Splitter £30 Headlights in good condition no marks £30 Standard clear indicators £15 Standard Series 2 wheels immaculate condition £200 RL7 7 spoke alloy wheels 5 available £750 Shell SOLD Smoked rear tail lights £30 Interior front seats and back seats £150 good condition small wear to drivers bolster. Front door cars one usual wear £40 90 spec. Immaculate front door cards £80 Carpet £40 Mint headlining £40 Rear door cards £20 Parcel shelf £10 http://i146.photobucket.com/albums/r269/timturbo/untitled-1.jpg Any chance of Pictures of Oil Breather/Catch tank and 40mm mk6 lowering springs please? Link to comment Share on other sites More sharing options...
mcflycossie Posted January 19, 2012 Share Posted January 19, 2012 PM Sent. Link to comment Share on other sites More sharing options...
timturbo Posted January 20, 2012 Author Share Posted January 20, 2012 http://i146.photobucket.com/albums/r269/timturbo/IMG_0719-1.jpg Link to comment Share on other sites More sharing options...
