demented Posted May 3, 2012 Share Posted May 3, 2012 Will new front struts/dampers for a 96 RS2000 fit a 98 Escort 1.8 3 door ? Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 3, 2012 Share Posted May 3, 2012 Don't think so, RS2000 runs an MTX75 box. Link to comment Share on other sites More sharing options...
demented Posted May 3, 2012 Author Share Posted May 3, 2012 What difference would the MTX75 box make to the type of dampers used ? Link to comment Share on other sites More sharing options...
Stu Posted May 3, 2012 Share Posted May 3, 2012 Never knew dampers bolted to the gearbox. Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 3, 2012 Share Posted May 3, 2012 I just assumed you meant hubs as well. Link to comment Share on other sites More sharing options...
Stu Posted May 3, 2012 Share Posted May 3, 2012 I just assumed you meant hubs as well. Do the IB5 and MTX75 hubs have different damper mountings? Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 3, 2012 Share Posted May 3, 2012 I just assumed you meant hubs as well. Do the IB5 and MTX75 hubs have different damper mountings?I was thinking driveshafts, doesn't the mtx run different ones to the ib5. I just assumed you meant hubs as well. Do the IB5 and MTX75 hubs have different damper mountings?I was thinking driveshafts, doesn't the mtx run different ones to the ib5. double post fail. Link to comment Share on other sites More sharing options...
demented Posted May 3, 2012 Author Share Posted May 3, 2012 As Ahmotorsport suggest, due to the different type of gearbox and driveshafts, is the diameter of the spindle carries, which accepts the bottom of the damper a different size on the Escort RS2000 to that of a 1.8 ? Link to comment Share on other sites More sharing options...
POSTIE Posted May 3, 2012 Share Posted May 3, 2012 As Ahmotorsport suggest, due to the different type of gearbox and driveshafts, is the diameter of the spindle carries, which accepts the bottom of the damper a different size on the Escort RS2000 to that of a 1.8 ? there all the same used rs dampers on a gti(ib5) and a tdi(mtx) fitted fine Link to comment Share on other sites More sharing options...
ScORTED Posted May 3, 2012 Share Posted May 3, 2012 As Ahmotorsport suggest, due to the different type of gearbox and driveshafts, is the diameter of the spindle carries, which accepts the bottom of the damper a different size on the Escort RS2000 to that of a 1.8 ? there all the same used rs dampers on a gti(ib5) and a tdi(mtx) fitted fine winner winner chicken dinner Link to comment Share on other sites More sharing options...
