Cooling system issue?
Mike-evans
Ive noticed over the last week that the temp gauge on my GTi is going up to the red line.
Just got home from a 15mile drive and I poped the bonnet to check the coolant, I can hear the cooling system bubbling as its cooling down. I opened the cap to release some pressure and the water has bubbled up and completely filled the expansion tank :unsure:
Is this normal?
Air lock, HG failure etc......?
Does the fan come on?
This is something I will have to check and report back lol...
When it gets upto the top of the gauge I put the heaters on hot and then that brings it back down..
Ive just gone out and checked the water and its sat just under the max mark (where its been for a while).
Just wasnt sure if the bubbling noise is normal?
Unplug the fan from the switch and bridge the two conductors in the connector (on the plug, not the switch). Ignition needs to be on.
Yep fan fires up when I bridge the connector - fan switch at fault?
What I dont understand is how this switch being faulty will make the cooling system bubble up? is it because the coolant/water is boiling up?
What temp should the fan be kicking in at?
If the fan isn't working the the water will continue to rise in temperature!!
If the hose the fan switch is in is hot then it's most likely the fan switch at fault. If the top pipe is cool or luke warm then you may have a faulty thermostat.
Top hose is boiling..
I've ordered a fan switch and will be in at 3 today.
Is it just a case of unscrewing it from the pipe?
Will I loose much water?
When the car is cold, take the expansion cap off and start the car up and just watch the coolant, does it bubble then?
Nope, not from what I can see. Its hard to look directly into the coolant with the way the expansion tank is shaped, but no bubbles visible looking into the tank side on..
What else could it be?
Cant get HG failure out of my head, but have no mayo substance on oil cap or dipstick.....
