Strange Q regarding siphoning my fuel
duke2k7
Guys,
Hope someone out there can help me out a little.
I have just bought a 57 plate focus and its time for my little escort to be retired. Thing is, its got a full tank o fuel, and there is far too much moneys-worth to simply let it go with the car.
If there a SAFE way to siphon the fuel without the silly option of bodging a hole in the tank? I'm not certain if I can or not, but there must be a way....
Hs anyone successfully emptied their escort's tank?
Hope you can help.
Cheers
Take a fuel pipe off the rail and switch the ignition on, let the pump do the work.
this will worrk for about two seconds then pump will shut down unless engine is running
Sorry, i think of how we do it on the Racers.
just connect a pipe to the return to a can then start the engine :thumb:
you could get a fuel pump connector from a breaker and bosh 12v into it that way, its how i emptied an escort once
you'd need to be extremely careful doing it like that
you need to be extremly carefull draining any fuel from a car lol as long as the pipe is a good fit on the return and dosn't leak and you dont walk away and leave it it will be ok
