emo Posted May 24, 2012 Share Posted May 24, 2012 hi just wondering if anyone can tell me which brake servo would be best to use on my mk 6 gti the brakes i will be using are front mk 1 v6 mondeo calipers and at the back mk 5 escort 130bhp rear calipers will the standard gti servo do the job? Link to comment Share on other sites More sharing options...
snoopaloopa Posted May 24, 2012 Share Posted May 24, 2012 Should do it ok I would have thought, I'm running 4 pots on the front and the 130 rear discs on a standard servo with no problems. Link to comment Share on other sites More sharing options...
ScORTED Posted May 24, 2012 Share Posted May 24, 2012 the 130spec one is ideal for calipers with bigger / more pistons; its discontinued by ford but it can be had as a pattern part (or could a few years back as my friendly ford dealer helped me track one down) Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 24, 2012 Share Posted May 24, 2012 hi just wondering if anyone can tell me which brake servo would be best to use on my mk 6 gti the brakes i will be using are front mk 1 v6 mondeo calipers and at the back mk 5 escort 130bhp rear calipers will the standard gti servo do the job?A servo is only a foot brake assist, it doesn't give you any extra disc clamping force, it just means you don't have to press so hard. For desired stopping power the question you should be asking is "Will my standard master cylinder be up to the job." Link to comment Share on other sites More sharing options...
etrebus Posted May 24, 2012 Share Posted May 24, 2012 hi just wondering if anyone can tell me which brake servo would be best to use on my mk 6 gti the brakes i will be using are front mk 1 v6 mondeo calipers and at the back mk 5 escort 130bhp rear calipers will the standard gti servo do the job?not sure but think you can fit a mondy one its a lot bigger in diameter though Link to comment Share on other sites More sharing options...
ScORTED Posted May 24, 2012 Share Posted May 24, 2012 arse didn't read this properly, the servos fine, its the master cylinder, that what i was on about Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 24, 2012 Share Posted May 24, 2012 arse didn't read this properly, the servos fine, its the master cylinder, that what i was on aboutI did wonder Link to comment Share on other sites More sharing options...
Naylor2006 Posted May 25, 2012 Share Posted May 25, 2012 I replaced my failed master cylinder with a pattern part which failed instantly on mondeo fronts and rs2k rears, and so did its replacement. Bad luck probably but the gen ford one which was more expensive did the job, it was an escort mk6 1.6/1.8 part rather than 130 spec one. Link to comment Share on other sites More sharing options...
emo Posted May 25, 2012 Author Share Posted May 25, 2012 I replaced my failed master cylinder with a pattern part which failed instantly on mondeo fronts and rs2k rears, and so did its replacement. Bad luck probably but the gen ford one which was more expensive did the job, it was an escort mk6 1.6/1.8 part rather than 130 spec one.thanks for the info guys will keep the standard one and wait for it to fail Link to comment Share on other sites More sharing options...
scottybo Posted May 26, 2012 Share Posted May 26, 2012 I replaced my failed master cylinder with a pattern part which failed instantly on mondeo fronts and rs2k rears, and so did its replacement. Bad luck probably but the gen ford one which was more expensive did the job, it was an escort mk6 1.6/1.8 part rather than 130 spec one.thanks for the info guys will keep the standard one and wait for it to fail what for it to fail? insurance details please lol Link to comment Share on other sites More sharing options...
