wwwd Posted June 12, 2012 Share Posted June 12, 2012 I'm in the process of moving house and getting the phone line and broadband sorted out this week. Been looking at how best to have the Internet as I want to have Internet access in quite a few different rooms - the office for the computers, lounge for the PS3, and in my room for my laptop. So I've found these: Clicky From what I gather, I can connect one to the router (which is in the hall) and then others to power sockets around the house and then connect these devices directly using a wired connection. I want to avoid wireless connections as I've always had nothing but trouble with them! Link to comment Share on other sites More sharing options...
Stu Posted June 12, 2012 Share Posted June 12, 2012 Yes that's how it works. You won't get the advertised speed and it highly depends on your particular house's wiring and interference. I've got some "80mbit" ones which could barely sustain 5mbit/sec in my old house. Wireless is potentially better if you use the right kit and set it up right. Link to comment Share on other sites More sharing options...
scottg17 Posted June 12, 2012 Share Posted June 12, 2012 Why not seeing as your moving house just get an Ethernet socket socket installed in each room, hook them up to a central switch and your laughing. Obv's there will be cost involved but would totally be worth it Link to comment Share on other sites More sharing options...
Hezz Posted June 12, 2012 Share Posted June 12, 2012 Why not seeing as your moving house just get an Ethernet socket socket installed in each room, hook them up to a central switch and your laughing. Obv's there will be cost involved but would totally be worth it thats what i'm doing, 4 port face plate where the router sits, pushing to two ports in front room and 2 ports in the back room, then all you need is the short rj45 leads from your router to how many point you need, if you havent got enough ports on the router just plug in the ones where you'll use it Link to comment Share on other sites More sharing options...
wwwd Posted June 19, 2012 Author Share Posted June 19, 2012 They (finally) arrived today and the only thing I can say about them is... they're simply fantastic. Getting 7MB/s speed with them which is fine so got one upstairs for the PC and another in the lounge for the PS3. Epic. Link to comment Share on other sites More sharing options...
EscortNreg Posted June 21, 2012 Share Posted June 21, 2012 Glad I stumbled across this! I have just ordered a set ( I think they're the same) http://www.ebuyer.com/263575-tp-link-200mb...ack-tl-pa211kit I got the tripple pack for £53.48 And I also ordered this; http://www.novatech.co.uk/products/network...mpaign=products To go behind the telly, so from the plug adapter I can run the Xbox, Wii, Smart TV, sky anytime+ and blu ray player. One thing I was wondering though, Can they be used on extension leads? Link to comment Share on other sites More sharing options...
EscortNreg Posted June 22, 2012 Share Posted June 22, 2012 Wish I waited a day, they have just been reduced to £33 for 2! Link to comment Share on other sites More sharing options...
wwwd Posted June 29, 2012 Author Share Posted June 29, 2012 I have just ordered a set ( I think they're the same) One thing I was wondering though, Can they be used on extension leads?Why didn't you use the eBay link I used? £33 for two, so I bought 2 packs (so I had 4 "sockets"). Unfortunately, they can't be used on extension leads, apparently. I say apparently because I just followed the guidelines in the documentation and have them straight into the main sockets on the wall. You could try it but it does say use it directly into the wall. I did do a lot of research on these things before splashing out on a specific set, so you're welcome. Link to comment Share on other sites More sharing options...
EscortNreg Posted June 30, 2012 Share Posted June 30, 2012 They can, and are being used on an extension lead. I did alot of testing with this, like plugging it into an extension lead, you're welcome! Link to comment Share on other sites More sharing options...
wwwd Posted July 5, 2012 Author Share Posted July 5, 2012 They can, and are being used on an extension lead. I did alot of testing with this, like plugging it into an extension lead, you're welcome!Really? And they work the same as on a regular socket? Link to comment Share on other sites More sharing options...
EscortNreg Posted July 6, 2012 Share Posted July 6, 2012 Yeah, even accessed the router from the end of an extension lead and the speed was the same. I'm having problems at the mo though, not due to extension leads as I'm not using any at the mo but I'm not getting any network (the middle light isn't on) I plugged an Ethernet into the laptop straight from the router an the net works fine. Strange. It's all been working fine untill now. Link to comment Share on other sites More sharing options...
wwwd Posted July 7, 2012 Author Share Posted July 7, 2012 You tried unplugging them and putting them back? And there's also a reset button at the bottom of those things. Link to comment Share on other sites More sharing options...
EscortNreg Posted July 7, 2012 Share Posted July 7, 2012 You tried unplugging them and putting them back? And there's also a reset button at the bottom of those things. I had to re sync them in the same double socket, never had to do it before but it worked. Plugged back into an extension lead, running through an 8 port Ethernet switch and running a smart telly, Xbox, wii, sky and blu ray player. No slowness in connection and I may even say its running better than when we had wireless. If you go onto the to-link website you can claim a free plug adapter at the mo. Tp-link not to-link lol P.s. I don't know what you have to do to get the free one, I just saw it when I went on there website. Link to comment Share on other sites More sharing options...
wwwd Posted July 9, 2012 Author Share Posted July 9, 2012 You tried unplugging them and putting them back? And there's also a reset button at the bottom of those things. I had to re sync them in the same double socket, never had to do it before but it worked. Plugged back into an extension lead, running through an 8 port Ethernet switch and running a smart telly, Xbox, wii, sky and blu ray player. No slowness in connection and I may even say its running better than when we had wireless. If you go onto the to-link website you can claim a free plug adapter at the mo. Tp-link not to-link lol P.s. I don't know what you have to do to get the free one, I just saw it when I went on there website.Free what sorry? Do you have a link? And by link I mean actual link, not that sh*t sidprick posts. http://www.evo-host.co.uk/getimg/29373.jpg Link to comment Share on other sites More sharing options...
sidrick Posted July 9, 2012 Share Posted July 9, 2012 Weyhey! There he goes Link to comment Share on other sites More sharing options...
