roboboyo Posted June 19, 2012 Share Posted June 19, 2012 Hi Guys was wondering if i could runmy 2ltr mondy engine on my 1600 scort managment, just for a month, until i can get the ecu sorted anyone done this? Link to comment Share on other sites More sharing options...
Stu Posted June 19, 2012 Share Posted June 19, 2012 If it does run, it's not a good idea. Probably won't be terrible if you only drive around at part throttle. Link to comment Share on other sites More sharing options...
roboboyo Posted June 19, 2012 Author Share Posted June 19, 2012 If it does run, it's not a good idea. Probably won't be terrible if you only drive around at part throttle. Cheers Stu, I have a pre pats ecu ready,but because of the money situation, i cant afford to do the engine change, And ecu at the same time, so they will be a month apart cant wait for the conversion though, would be quick enough to surprise some people Link to comment Share on other sites More sharing options...
Stu Posted June 19, 2012 Share Posted June 19, 2012 Huh? You have the ECU but you can't afford to what, swap a few wires over? Link to comment Share on other sites More sharing options...
roboboyo Posted June 19, 2012 Author Share Posted June 19, 2012 Huh? You have the ECU but you can't afford to what, swap a few wires over? I know,I have no confidence in electrics,so ill have to pay a fella to do it Link to comment Share on other sites More sharing options...
Naylor2006 Posted June 19, 2012 Share Posted June 19, 2012 Huh? You have the ECU but you can't afford to what, swap a few wires over? I know,I have no confidence in electrics,so ill have to pay a fella to do it Give it a shot mate, it's very very easy, the engine drop is harder, literally you remove the old ECU and swap some pins in the ECU plug, ok it's fiddly but there's no soldering or proper electrical work going on, no stripping wire either. Label the wires as the guide says in the 'how to' section and give it a bash, honestly your'll be fine. Link to comment Share on other sites More sharing options...
