Estate rear brakes
Billkent22
Well all the mk1 focus disc setups work but I forgot to mention you get a different offset (which spaces the wheels out)
IIRC they are approx:
Std Focus 260mm disc with +19mm offset each side
ST170 280mm disc with +19mm offset each side
RS Focus 280mm disc with +25mm offset each side (not really suitable for std escort)
Without ABS it just bolts straight up really, there are a couple of rivets to drill out
You need the rear sections of handbrake cable, longer rear brake hoses and some zip ties
Standard
