blacksofstichill Posted February 20, 2013 Author Share Posted February 20, 2013 New Timing Chain ready to be fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0185.jpg Sprockets and New Chain fitted with Timing Marks lining up between the two sprockets - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0186.jpg New Old Stock Genuine Ford Chain Tensioner and Pad - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0187.jpg Fitted and Tensioned up - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0188.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0189.jpg retapping the holes in the block to clean out the threads - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0190.jpg New Timing Cover Gasket fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0191.jpg Deflector plate fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0192.jpg Timing Cover fitted, the crank pulley is sitting in place to align the cover centrally around it so that the Oil Seal is sitting concentrically on the Crankshaft Pulley - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0193.jpg Bolts all tightened up, I can see I'll have a little bit of touching up to do - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0194.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0195.jpg Engine Removed from the Stand to fit the Crankshat Oil Seal and Housing - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0196.jpg New Gasket fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0197.jpg Crank Seal and Housing fitted, ensuring the seal is concentric to the crankshaft when you tighten it up is critical to ensure it has a good seal - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0198.jpg Back onto the stand and the engine is flipped over - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0199.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0200.jpg Dipstick Tube and Pickup Pipe fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0201.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0202.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0203.jpg New Sump Gaskets ready to fit - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0204.jpg Gaskets fitted to the block - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0205.jpg Sump fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0206.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0207.jpg Sump Plug fitted with new washer - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0208.jpg And fitted to the Sump - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0209.jpg Engine turned back over again - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0210.jpg Link to comment Share on other sites More sharing options...
Naylor2006 Posted February 20, 2013 Share Posted February 20, 2013 Lovely stuff Link to comment Share on other sites More sharing options...
blacksofstichill Posted February 20, 2013 Author Share Posted February 20, 2013 Thanks, much appreciated! Oil Pump fitted with new gasket - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0211.jpg And Oil Pump fitted to the Block - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0212.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0213.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0214.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0215.jpg Crank Pulley Fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0216.jpg That's the bottom end all done for now so it's covered up while work starts on the head - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0217.jpg Cylinder Head as removed - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0218.jpg Valve Spring Compressed and retaining collets removed - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0219.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0220.jpg Valve Spring removed - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0221.jpg First Valve removed - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0222.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0223.jpg All Valves, Springs, Collets and Stem Seals removed - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0224.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0225.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0226.jpg Cylinder Head Stripped bare and ready for Sandblasting - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0229.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0230.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0231.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0232.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0233.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0234.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0235.jpg Link to comment Share on other sites More sharing options...
parky1 Posted February 20, 2013 Share Posted February 20, 2013 absolutely amazing work, top quality stuff. Link to comment Share on other sites More sharing options...
blacksofstichill Posted February 21, 2013 Author Share Posted February 21, 2013 Thanks Parky! With the head away being sandblasted I turned my attention to the engine mounts - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0236.jpg Cleaned back to bare metal - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0237.jpg Primed and Painted in Gloss Black - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0238.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0239.jpg I got my good Friend Andrew to sandblast the Cylinder Head for me, it makes a great job on a cast iron head like this and cleans the ports out much better than I could do by hand - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0240.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0241.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0242.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0243.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0244.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0245.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0246.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0247.jpg This head is going to be converted to run on Unleaded Petrol, so to do that I have to machine out the existing Exhaust Valve Seats, Press in Hardened Valve Seat inserts and cut them to the correct seating angle. Here are the hardened inserts as I bought them - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0248.jpg Here is one of the existing standard exhaust valve seats - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0249.jpg With the insert just laid on top of the seat you can see its a suitable diameter to do the job as it will just fit within the shallow combustion chamber - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0250.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0251.jpg Inserts like this aren't made for each individual engine, you just buy them from a range of standard sizes and it's up to you to measure the size you need for the job. In this case I was able to get an insert with the right inside and outisde diameter but Ideally I wanted one around 5mm deep as that's all they need to be for this head, however that size was going to take around 4 weeks to arrive which I wasn't prepared to wait. So, these ones I ordered which were available off the shelf were the correct diameters but 9.5 deep rather than 5mm so I machined them down to size on the centre lathe - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0252.jpg With one done you can see the difference - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0253.jpg All done, much better than waiting a month for ones made in this depth - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0254.jpg Cylinder Head onto the Milling Machine to machine the old seats out - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0255.jpg With the Roughing Cutter centralised on the existing Valve Seat it's time to rough out the old seat - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0256.jpg Halfway there - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0257.jpg One seat Machined out to a roughing diameter, I have another cutter ordered to do a finishing cut which will leave the recess in the head the correct size to provide an interference fit when the new seat inserts are pressed into place - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0258.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0259.jpg Link to comment Share on other sites More sharing options...
ganges Posted February 21, 2013 Share Posted February 21, 2013 fascinating stuff, love it, proper workmanship, which in my opionion is hard to come by these days Link to comment Share on other sites More sharing options...
Ahmotorsport Posted February 21, 2013 Share Posted February 21, 2013 Not many people realize just how bad the ports were in old engines! :') Top work as always, jealous you have the tools to put valve seats in! Link to comment Share on other sites More sharing options...
rs2k_mad Posted February 21, 2013 Share Posted February 21, 2013 nice work, really enjoying following this thread, keep it up Link to comment Share on other sites More sharing options...
sidrick Posted February 21, 2013 Share Posted February 21, 2013 Great updates as per usual, but PM me your address and I'll send you some latex gloves free of charge, you clatty b*stard Link to comment Share on other sites More sharing options...
blacksofstichill Posted February 22, 2013 Author Share Posted February 22, 2013 fascinating stuff, love it, proper workmanship, which in my opionion is hard to come by these days Thanks, I really appreciate that, glad you're enjoying the thread. Not many people realize just how bad the ports were in old engines! :') Top work as always, jealous you have the tools to put valve seats in! Cheers, yeah the ports aren't too well cast on these at all, thats just the way they all seem to be from that era! Regarding the valve seat inserts, you can buy machines specifically to cut out valve seats for inserts but they're expensive and rarely available second hand unfortunately so I just make use of the milling machine whic to be honest is just as handy. Glad you are enjoying the prgress so far. nice work, really enjoying following this thread, keep it up Thanks, really appreciate that happy to hear you are enjoying it. Great updates as per usual, but PM me your address and I'll send you some latex gloves free of charge, you clatty b*stard Thanks, glad you like the updates! Thanks for the offer of gloves, I've never worn gloves when I'm working, some nights I have to wash my hands in petrol or thinners to get them clean though! Another update for you, with the finishing cutter arriving I was able to machine out the recesses in the head to there finished size. This cutter is basically acting as a reamer to finish the hole off, it isn't removing much material at all. Ready to cut - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0260.jpg After cutting - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0261.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0262.jpg The first recess finished - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0263.jpg All 4 Exhaust Valve Seats machined out accurately - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0264.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0265.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0266.jpg Onto the hydraulic press and it's time to press in the seat inserts - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0267.jpg First insert laid in place ready to be pressed in - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0268.jpg Just starting to ease it in - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0269.jpg And pressed right in - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0270.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0271.jpg All four inserts pressed in - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0272.jpg You can see a step below the insert where it meets the original casting, rather than leave them like that I dress the step down using a die grinder - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0273.jpg Similarly, you can see step lines in the casting of the inlet and exhaust ports and irregularities in the shape of the ports - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0274.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0275.jpg So, after a bit of time with the die grinder I've got any steps behind the inserts tidied up and thhe casting flaws smoothed out. Please don't confuse this with porting and polishing, it's just a little bit of work to tidy the casting up, not to increase port size dramatically - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0276.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0277.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0278.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0279.jpg So, that's all the inserts fitted and the casting tidied up but the inserts still need to be cut to the valve angle - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0280.jpg Pilot fitted into the valve guide gives me a centre to work on - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0281.jpg Neway 45 degree carbide cutter will rough the seat down to size - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0282.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0283.jpg Cutter guided down on the pilot - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0284.jpg After a bit of cutting - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0285.jpg Valve seat roughed down to depth at 45 degress - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0286.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0287.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0288.jpg All Exhaust Valve seats roughed down - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0289.jpg Link to comment Share on other sites More sharing options...
Ahmotorsport Posted February 22, 2013 Share Posted February 22, 2013 We got a set of those Neways, they aren't cheap! Link to comment Share on other sites More sharing options...
blacksofstichill Posted February 25, 2013 Author Share Posted February 25, 2013 We got a set of those Neways, they aren't cheap! You're right, they're anything but cheap those things! Pilot re-fitted into the guide and this time I'll use the seat grinder just to finish the seat off nicely - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0290.jpg Ready to go, this cutter is driven by a tool similar to an electric drill - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0291.jpg The finished seat - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0292.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0293.jpg Onto the inlet valves and this time its a slightly larger cutter/grinder used - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0294.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0295.jpg Job Done - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0296.jpg Moving onto the valves themselves, here they are as removed from the engine - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0297.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0298.jpg And after a clean up with the wire brush on the Bench Grinder - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0299.jpg Exhaust Valve showing some heavy pitting and the seating face is curved rather than flat due to wear - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0300.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0301.jpg Inlet Valves aren't too bad, just a bit of wear as expected on the seating face - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0302.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0303.jpg Exhaust Valve onto the lathe - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0304.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0305.jpg Cleaned and polished up - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0306.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0307.jpg Inlet Valve onto the lathe - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0308.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0309.jpg Cleaned and polished up - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0310.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0311.jpg All Valves cleaned and polished on the lathe - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0312.jpg Inlet Valve ready to go onto the valve refacer - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0313.jpg Ready to go - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0314.jpg Seating face reground - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0315.jpg Exhaust Valve is going to take a bit more work - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0316.jpg Set up and ready to go - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0317.jpg And reground - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0318.jpg All Valves now refaced - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0319.jpg Link to comment Share on other sites More sharing options...
Georgio Posted February 25, 2013 Share Posted February 25, 2013 I am watching clesely your thread.All that really good work on an engine.Congratulations.I also have to admit that I love all the hardware in your shop,really envy :-p Just a minute,I am drooling!.lol.Nice work. Link to comment Share on other sites More sharing options...
blacksofstichill Posted February 26, 2013 Author Share Posted February 26, 2013 I am watching clesely your thread.All that really good work on an engine.Congratulations.I also have to admit that I love all the hardware in your shop,really envy :-p Just a minute,I am drooling!.lol.Nice work. Many Thanks, really glad to hear you're finding it interesting and enjoying the thread, much appreciated! http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0320.jpg starting to lap the valves in now - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0321.jpg First exhaust valve lapped in, you can see the dark "band" on the valve seat, when this band continues right around the seat that's when you have the valve correctly lapped in - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0322.jpg And you can see the corresponding "band" on the valve itself - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0323.jpg All valves lapped in - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0324.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0325.jpg Cylinder Head back onto the Milling Machine - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0326.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0327.jpg Head skimmed by the minimum amount to clean up the face - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0328.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0329.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0330.jpg Head casting fully degreased and washed out to remove any grit from blast and swarf from machining, etc - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0331.jpg New Valve Stem Oil Seals - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0332.jpg First Valve fitted through the guide - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0333.jpg And Stem Seal fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0334.jpg Valve Spring fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0335.jpg Spring Cap fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0336.jpg Valve Spring compressed - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0337.jpg Retaining Collets fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0338.jpg Spring Compressor off - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0339.jpg All Valves, Stem Seals, Springs, etc fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0340.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0341.jpg Looking closely, you can just make out the outline of the hardened exhaust valve seat on the left - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0342.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0343.jpg New Cylinder Head Gasket fitted - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0344.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0345.jpg Cylinder Head fitted and Torqued down - http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0346.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0347.jpg http://blackengineering.co.uk/images/Mk2-Cortina-1600E-Crossflow-Engine-Reconditioning/0348.jpg Link to comment Share on other sites More sharing options...
ganges Posted February 26, 2013 Share Posted February 26, 2013 Well i would like to say something.................but, i am lost for words, great update yet again (shurrapp Sid) Link to comment Share on other sites More sharing options...
