Andyb0127 Posted March 15, 2013 Share Posted March 15, 2013 Just a basic guide for those interested. Stage 1 - PreparationThe first thing to do is obviously remove the part/s you wish to paint, be careful not to scratch them as this will mean more work for yourself. Before you can start with the primer it is vital to key the surface of the car part and remove any 'bobbles' which are common on many exterior plastic parts. The bump strips I am colour coding had these bobbles on and from experience I have learned how important it is to completely smooth them out using sandpaper. I started with 150grit, then 800grit and finally finished off with some 1200 grit to get a smooth finish ready for priming. This a bit of a rubbish job as sandpaper doesn't seem to work too well on plastics and tends to get gunked up quite quickly meaning you go through quite a few sheets. I cannot stress enough how important it is to take your time on this and get a nice smooth surface. For parts which don't have bobbles on it is still important to key the surface and remove the shine, if you don't do this the primer cannot take properly and 3 months down the line the paint will probably start to flake off. Once everything is nice and smooth give it a really good clean with some warm soapy water and then rinse with cold water. This is important to completely degrease the surface and get rid of any grim which has built up over the years (especially if it is an external part). Soaps have all sorts of chemicals in which you don't really want to leave on the part in case they react with the paint. Better to be safe and just rinse it all off. Leave the part to dry somewhere it won't get dusty and have a cup of tea safe in the knowledge that stage one is complete. Stage 2 - PrimerFinding a good place to do the painting can be tricky, sheds/garages are ideal. A couple of pointers to consider:Clean - There's nothing worse than finding a some bits of dirt/fluff/dust have landed in your paint whilst you are in the middle of putting a layer on.Warm, dry, low humidity - All of these things are essential conditions for the paint to dry quickly and properly.Indoors - I guess you could spray outside if you really needed to but I imagine you would use double as much paint and the chances of some sort of insect/cat/grass messing up your meticulous painting is increased.As you are spraying onto plastic make sure you have special plastic primer and not normal primer. Read the instructions on the can. Shake it hard for a minute until you can hear the ball rattle and make sure the can is at room temperature. Apparently if the can is cold it reduces the pressure which means the paint doesn't spray in as fine a mist. Spraying techniqueYou want to apply the paint in even, consistent layers. Here's some pointers on technique:Hold the nozzle about 6 inches away from the part.Smoothly move the can across the face of the part always keeping the can upright.Begin spraying before you move over the part and continue to spray until you have passed it completely.Try to imagine your arm is a spraying robot from a mass production assembly line. Smooth. It will take a bit of time to find the right speed which gives the best results. It's a balance between the layer of paint being too thin (wasting paint and taking ages) and being too thick (risking getting paint runs). Remember, just take your time. TIP: Watch out for the very edges of the part as it can be easy to go too thin on these especially if the part is laid flat on the table and not hung up. Three/four decent coats of primer will be enough, wait 20 minutes between coats to allow for each layer to dry sufficiently. Once the last coat is on leave them somewhere warm to dry for a few days. I generally wait until the solvents have stopped evaporating. Easiest way to tell this is put your nose close to the part and take a good sniff. As the old saying goes - "if it still smells like paint, you'll have to wait" or something like that. The next stage is wet sanding... Stage 3 - Smoothing the primerNo matter how well you prepared the surface and how even your spraying was, the primer will have taken on a semi-rough texture. I don't know why, must be something to do with how the paint molecules settle and dry. We need to remove this roughness by wet sanding. Leave the wet and dry to soak for 10 mins before usingFill a tub with warm soapy water and leave your 2500grit wet and dry paper to soak for 10 minutes. Dip your hand in the soapy water and give the part a little rub to get it nice and wet as well. Now take the 2500grit wet and dry paper and gently move it in one direction with a very light amount of pressure across the surface of the primer. Move your fingers over the area you have just wet sanded, it should feel completely smooth. Now do the same thing over a bit you haven't touched yet, feel the difference? When the part is wet it is almost impossible to tell which bits have been smoothed and which bits haven't by looking so I just tend to do it by touch. You should find the water running off the part is grey colour (or whatever colour your primer is) this is nothing to worry about. If there are any runs in the primer now is the time to gently correct them by spending a bit of extra time sanding over that particular area to get it nice and flat. Using a sanding block or similar flat surface is advisable. Once everything is lovely and smooth give the car part a decent rinse with some cold water to remove any primery water. If you don't do this it will dry into a dust which you will have to wipe off before doing the colour coat. Primer - completely smooth after being rubbed down with 2500 grit Stage 4 - Colour CoatYou should now have an erotically smooth primer base ready for the colour coat. Use the same spraying technique as described above, taking extra care to give good coverage to any awkward edges. You'll be rather annoyed if you go to smooth out the colour coat and some grey primer rears its ugly head because the paint was so thin. Four/five decent coats of colour should be sufficient with 20 mins drying time in between. Once this is done leave to dry for approximately three days. You can speed the process up by putting the part on top of a radiator on a low heat. Again I went by the smell test to know when the paint was sufficiently cured to wet sand. Stage 5 - Smoothing the colour coatBy now a lot of people myself included are probably getting a bit bored of all this waiting around and felt a great urge to cut some corners. Resist the temptation, you've put too much time in now to mess things up for the sake of a few hours. If everything has gone to plan you should have a pretty decent looking finish already, any reflections will probably be a bit fuzzy but there is plenty of time left to correct that. The next part of the guide is specific to solid colours i.e. not metallic/pearlescent. Follow exactly the same process as we did when smoothing the primer. A light amount of pressure is all that is required. Again it is important to rinse the soapy water off to avoid any potential reactions with the clear lacquer. After you have wet sanded the colour coat you will notice it now has a dull matte appearance once dry and may be thinking something a long the lines of "Oh s*#t I've ruined it". Do not fear this is meant to happen. Stage 6 - Clear Lacquer Almost there comrades. Use the same spraying technique again but bare in mind that lacquer generally seems to be heavier than primer and colours so be extra careful to avoid runs. As you apply the lacquer you should see the dull finish spring back to life and take on a lovely deep gloss appearance. How many coats of lacquer should I apply? Three or four decent coats will be sufficient. Wait 20 - 30 minutes in between each coat. Again take extra care to get good coverage on the edges. Leave the car parts somewhere warm and dry for about a week. Stage 7 - Cutting and polishingApplying polish to the lacquer before it has fully cured can spell disaster. I waited a week for my bump strips to fully dry but depending on the size of the part and the temperature this may take longer. To tell if the lacquer is ready give it a smell to see if the solvents are still evaporating. Even when you can't smell anything i'd personally still give it another day or two just to be on the safe side. Most rattle cans have instructions on the side specifically warning against using any polish or compound until the lacquer has completely cured. This is the final stage where you smooth out the lacquer and correct any nasty looking orange peel. If everything has gone well you should have a decent enough looking finish already but with a bit of a cut and polish this can be improved dramatically. Before cutting and polishingIt is up to you what type of cutting compound to use. I have used Meguiars Scratch X which is relatively mild with good results but some people might prefer to use something harsher such as G3. Apply a small blob of cutting compound to the center of the polishing pad and start rubbing! Apply a medium to hard pressure and focus on small areas at a time, working the compound in and breaking it down. You should find the optical quality of reflections has been improved dramatically from the cutting process, the last stage would be to use a polish such as Autoglym Super Resin Polish to give that final mirror finish. After cutting and polishing with Meguairs Scratch X and SRPI made a mistake with these bump strips by not doing a proper job of sanding out the plastic when I first started. You can see in the above photo that although the finish is quite good it still looks uneven. This is the surface of the plastic coming through all the layers. When doing the other side I spent more time sanding out the imperfections and the results are alot better. Link to comment Share on other sites More sharing options...
sidrick Posted March 15, 2013 Share Posted March 15, 2013 Nice write up. Link to comment Share on other sites More sharing options...
Ahmotorsport Posted March 15, 2013 Share Posted March 15, 2013 Cheers fella! I can't see a picture though Link to comment Share on other sites More sharing options...
lee grout Posted March 16, 2013 Share Posted March 16, 2013 Good informative write up, only thing I would of added is the optional use of a guide coat in the priming stage to see if you have any low spots. And what AHM said, pics please Link to comment Share on other sites More sharing options...
