blacksofstichill Posted July 18, 2013 Author Share Posted July 18, 2013 Yes, you can definitely cause problems if you grind the valves back too much to reface them, the most common problem is that the edge of the valve becomes too sharp and it leads to the valve being burned at this point, it would have to be very badly pitted for this to happen though and it would be a case of renewing the valves at that stage. The tappets or valve lifters follow the profile of the camshafts and in turn this allows them to push the valves open or allow the valves to close. Hydraulic tappets (as opposed to mechanical/solid lifters) use oil pressure to maintain zero valve clearance so they never need any adjustment. The replacement head, like the original one had dulled quite a bit and had some surface corrosion to the outer surface which is purely cosmetic but in the interests of making the engine look it's best I masked it up ready for painting - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0309.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0310.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0311.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0312.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0313.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0314.jpg I Painted it with Simoniz Silver Engine Enamel, I've used it before and it seems to work well - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0315.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0316.jpg Masking Tape removed - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0317.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0318.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0319.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0320.jpg I laid it onto the block for the paint to dry and also to see how it looked - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0321.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0322.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0323.jpg With the paint set on the Cylinder Head I removed it from the block to fit it properly - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0324.jpg Delving into the box of tricks Olly sent up we have a Genuine Ford Multi Layer Steel Head Gasket - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0325.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0326.jpg Gasket laid in place and one last look at the fresh bores and those cracking pistons - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0327.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0328.jpg Cylinder Head Laid into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0329.jpg New Cylinder Head Bolts - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0330.jpg Head Torqued down - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0331.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0332.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0333.jpg The original Bolts for the Cam Sprockets and the Chain Guides had long since seen better days, the heads were all chewed up and the threads had been loctited - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0334.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0335.jpg So, into my stock of spares and I replaced them with good ones - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0336.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0337.jpg Link to comment Share on other sites More sharing options...
sidrick Posted July 18, 2013 Share Posted July 18, 2013 Sexual update! Link to comment Share on other sites More sharing options...
blacksofstichill Posted July 18, 2013 Author Share Posted July 18, 2013 Cheers! Here's some more for you.....New Timing Chain kit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0338.jpg The AE Timing Chain is top quality but as you'll see it has no coloured links to line up the timing marks with - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0339.jpg So, after laying it out alongside the Rolon one I painted my own markings on the correct links, although the coloured links aren't essential they do provide a good double check - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0340.jpg Original Timing Chain guide was mint, it must have been replaced during the last rebuild as there was no sign of any wear on it at all - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0341.jpg Chain Fitted to the crank sprocket - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0342.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0343.jpg New Tensioner plunger - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0344.jpg Fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0345.jpg New Tensioner Sprocket ready to fit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0346.jpg Fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0347.jpg Cams ready to fit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0348.jpg Inlet Cam is standard RS profile - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0349.jpg Exhaust Cam is a custom Regrind by Kent Cams - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0350.jpg At the top of my thumbnail on this photo you can see where the new grind meets the old one on the chamfer - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0351.jpg Kent Cams stamping on the casting - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0352.jpg Lift of the Exhaust Cam is reduced from Standard - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0353.jpg Cams Laid in place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0354.jpg Cam Bearing Cap Studs fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0355.jpg Cam Bearing Caps fitted and torqued down - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0356.jpg Sprockets fitted and Cams Timed up - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0357.jpg New Chain Guide - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0358.jpg Fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0359.jpg Tensioner Plunger releases to take up the slack and that's it all timed up - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0360.jpg Upper Timing Cover ready for a clean up - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0361.jpg Cleaned up ready to paint - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0362.jpg And painted with Silver Engine Enamel to match the head - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0363.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0364.jpg Lower timing cover as removed from the engine - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0365.jpg Old Oil Seal removed and New one ready to fit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0366.jpg New Oil Seal fitted and cover cleaned up ready to fit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0367.jpg Also, here are a few Tech Specs for this engine from the measurements I took and calculations I made before I built it all up - Bore - 86.5mm (0.5mm overbore)Stroke - 86.0mm (standard RS)Capacity - 2022ccCompression Ratio - 7.36:1 Link to comment Share on other sites More sharing options...
blacksofstichill Posted July 19, 2013 Author Share Posted July 19, 2013 Crankshaft Oil seal and housing as removed from the engine - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0368.jpg Old Oil Seal removed on the left, new one ready to fit on the right - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0369.jpg New Oil Seal fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0370.jpg New gasket ready to fit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0371.jpg Gasket fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0372.jpg And fitted to the engine - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0373.jpg Moving on to the exhaust manifold, we decided to use the one that was already fitted to the engine rather than have a 200SX based one made up. The fact this manifold had already been fitted and worked was part of the reason but it also keeps the cost down on the overall project and will avoid clearance issues with the radiator, etc as this manifold tucks tightly into the block - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0374.jpg The only thing against this manifold that neither Olly or me liked was the Welding on it. It was a solid enough job and Stevie Wonder may have been delighted with how it looked but we weren't - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0375.jpg Masses of big ugly welds weren't doing it a lot of favours - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0376.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0377.jpg On the plus side, the inside of the manfiold had been well matched to the RS2000 flange after all that welding - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0378.jpg So, to improve its looks I started dressing down the welds and grinding off casting marks and casting numbers, ect - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0379.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0380.jpg It still looks a bit rough at this point but bear with me - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0381.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0382.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0383.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0384.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0385.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0386.jpg Then I spent some timg going over it all with a flap wheel on the grinder to smooth it a bit further - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0387.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0388.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0389.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0390.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0391.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0392.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0393.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0394.jpg With it looking a lot smoother and cleaner now I coated it with a high temp black and lacquered it - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0395.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0396.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0397.jpg I know it won't stay as glossy as that for long once it's had some heat through it but it looks as best as it can for now Link to comment Share on other sites More sharing options...
sidrick Posted July 19, 2013 Share Posted July 19, 2013 Holy shitfuck. Amazing transformation on that manifold! Link to comment Share on other sites More sharing options...
blacksofstichill Posted July 20, 2013 Author Share Posted July 20, 2013 Thanks, it took a bit of time but it was worth it when you see the difference it made. I popped it onto a couple of exhaust studs to see how it looked although it all maybe looks a bit "black" against the engine block there'll be a breather pipe running behind it which I'll paint in Silver to add some contrast and once the Turbo is bolted back onto it that'll break it up a bit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0398.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0399.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0400.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0401.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0402.jpg Next I decided to have a better look at the fuel rail, here it is as removed from the engine - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0403.jpg As you can see, it has top feed injectors fitted into the standard inlet and using a steel fuel rail which has become quite rusty - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0404.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0405.jpg Non-standard Weber Fuel Pressure Regulator - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0406.jpg One-way valve on the breather pipe to prevent boost pressure from entering the inlet manifold - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0407.jpg Fuel Rail and injectors removed from the Inlet - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0408.jpg As can be seen from the photos, the injectors have been fitted into the inlet by using parts of the original fuel rail cut to suit, quite clever really, does the job very well - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0409.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0410.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0411.jpg Injectors all removed from the Fuel Rail - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0412.jpg Fuel rail all cleaned back to good metal - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0413.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0414.jpg Primed - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0415.jpg Painted in Satin Black - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0416.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0417.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0418.jpg The inlet manifold itself is in need of a really good clean up before being painted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0419.jpg Luckily, I was saved from cleaning the inlet that day when Olly had a load of Goodies for the engine delivered to me - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0420.jpg Brand new Oil Pump - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0421.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0422.jpg It might be a new pump but I'm still taking no chances with the Pressure Relief Valve screw coming slack, so I removed it - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0423.jpg A few Dabs of loctite on the threads - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0424.jpg And refitted it - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0425.jpg Link to comment Share on other sites More sharing options...
lee grout Posted July 20, 2013 Share Posted July 20, 2013 I love this stage, when things get tarted up and its all coming together now From the last pic before paint to the finished article, how much grinding/smoothing did you do....time wise? from the early grinds it looks a bit angular and the finished product looks rounded and smooth as a baby's bum. P.S great job.....as if you needed reminding Link to comment Share on other sites More sharing options...
blacksofstichill Posted July 26, 2013 Author Share Posted July 26, 2013 I love this stage, when things get tarted up and its all coming together now From the last pic before paint to the finished article, how much grinding/smoothing did you do....time wise? from the early grinds it looks a bit angular and the finished product looks rounded and smooth as a baby's bum. P.S great job.....as if you needed reminding Cheers! I think I had around 2 hours work on that manifold from start to finish, made all the difference to how it looks though so well worth it. Oil Pump fitted to the Engine - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0426.jpg New Oil Pump Chain ready to be fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0427.jpg And fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0428.jpg New Oil Pump Tensioner Pad, check out the wear on the old one - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0429.jpg Tensioner Fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0430.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0431.jpg Bottom Timing Cover ready to fit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0432.jpg Fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0433.jpg Another one of Olly's purchases was this Bottom Pulley which was in better condition than our existing one - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0434.jpg There were a few bits of rust starting to come back through on it though - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0435.jpg So, I rubbed it down - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0436.jpg Primed it - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0437.jpg And Painted it in Satin Black - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0438.jpg Bottom Pulley fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0439.jpg Upper Timing Cover ready to fit along with Gasket whcih was also from Olly's latest delivery - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0440.jpg Upper Timing Cover fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0441.jpg It's taking shape now - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0442.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0443.jpg Another excellent purchase by Olly, a New Water Pump - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0444.jpg Just to help it look good for longer, I coated it with Silver Engine Enamel - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0445.jpg New O-ring fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0446.jpg Another item from the big box of tricks, powder coated Water Pump Pulley - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0447.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0448.jpg Water Pump fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0449.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0450.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0451.jpg Link to comment Share on other sites More sharing options...
scottybo Posted July 26, 2013 Share Posted July 26, 2013 if you dont mind me asking, what sort of price would you charge for this kind of conversion? Link to comment Share on other sites More sharing options...
sidrick Posted July 26, 2013 Share Posted July 26, 2013 Really coming together now! Link to comment Share on other sites More sharing options...
blacksofstichill Posted July 30, 2013 Author Share Posted July 30, 2013 if you dont mind me asking, what sort of price would you charge for this kind of conversion? It's hard to put a total price on it as my part of the job is pretty much labour only with the customer supplying the parts and the parts are often the most expensive element. The bare engine though built up to pretty much the stage you see it at just now would be around £600 plus VAT in labour. That leaves it at the stage where manifolds and all the other external elements are ready to be fitted. As you see this project progress though you'll see that I've had to do quite a lot of other work so the overall cost is considerably higher than just the bare engine itself. If someone was doing the rest of the work themself after the engine stage though you could keep the costs down. Really coming together now! Cheers! Next up to sort out was the sump - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0452.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0453.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0454.jpg After a bit of cleaning and degreasing it looked like this - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0455.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0456.jpg After a light rub down I coated it in Silver Engine Enamel - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0457.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0458.jpg New Sump Gasket fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0459.jpg Sump fitted to the engine - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0460.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0461.jpg Sump Plug with New Washer - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0462.jpg Fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0463.jpg Engine turned over again - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0464.jpg Into the box of tricks again, this time for a new metal Exhaust Gasket - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0465.jpg Exhaust Studs fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0466.jpg Gasket fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0467.jpg Manifold fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0468.jpg Space is very tight to get the nuts onto a couple of the studs but other than that it fits perfect - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0469.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0470.jpg Moving onto the Cam Cover now, the original one had been badly painted in Red - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0471.jpg So, rather than spend ages cleaning the paint off, I swapped it for another one I had in stock, the Red one can always be blasted and coated at some point rather than trying to clean all that paint off by hand - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0472.jpg And after being degreased it came up well - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0473.jpg Masked off for painting - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0474.jpg Primed - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0475.jpg And Pinted in Satin Black, it's still wet at this point, hence the glossiness - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0476.jpg Laid onto the engine for the paint to cure - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0477.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0478.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0479.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0480.jpg Link to comment Share on other sites More sharing options...
blacksofstichill Posted July 30, 2013 Author Share Posted July 30, 2013 Cam Cover gasket fitted, the old ones were re-used as they were in good order and the new ones in the gasket set aren't a good fit at all - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0481.jpg Cam Cover laid onto the Head - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0482.jpg Into my stockpile and out came some Stainless Bolts and Nuts - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0483.jpg Fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0484.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0485.jpg Cam sensor from the Box of tricks ready to fit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0486.jpg And fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0487.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0488.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0489.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0490.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0491.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0492.jpg Crank Sensor supplied by Olly, this one is correct as it's for a Mk6, the one from the original block was a Mk5 one and no good for this new engine - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0493.jpg And fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0494.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0495.jpg Link to comment Share on other sites More sharing options...
Hezz Posted July 30, 2013 Share Posted July 30, 2013 Cracking work what's the rs2k look like its going into? Link to comment Share on other sites More sharing options...
blacksofstichill Posted August 1, 2013 Author Share Posted August 1, 2013 Cheers! I'll have some pics up of the car itself later in the thread, there has been a lot of work done to it too so there are loads of updates still to come! Here is the Turbo as removed from the engine and sent back down to the Owner who was getting it refurbished locally - http://i579.photobucket.com/albums/ss237/doctorevil72/IMG_3907_zpsaf77f624.jpg http://i579.photobucket.com/albums/ss237/doctorevil72/IMG_3908_zps1ae3b4bf.jpg He was reccomended to take it to local specialists - CR Turbos in New Milton for a diagnosis http://i579.photobucket.com/albums/ss237/doctorevil72/IMG_3920_zps95355d29.jpg He said it is a T34 compressor from an Escort Cosworth mated to a Saph 4x4 turbine housing with a .46 a/r and a 270 degree bearing. He said it would be good for p 350bhp + once refurbed wityh a 360 degree bearing. This is the last shot of the turbo on their reception counter next to some of their demonstartion cutaway models http://i579.photobucket.com/albums/ss237/doctorevil72/IMG_3921_zpsc908194f.jpg Olly had sent up a Thermostat Housing in good order, some of the sensors may be changed depending on what management is used but we'll cross that bridge when we come to it - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0496.jpg New O-ring fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0497.jpg Fitted to the head - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0498.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0499.jpg Another great item in the spares box, a powdercoated bracket to mount the Alternator and Power Steering pump, it also had a good tensioner with a powdercoated pulley - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0500.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0501.jpg Fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0502.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0503.jpg Engine Mount Bracket, also powder coated - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0504.jpg Fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0505.jpg Here is the Crank Vent Piping as removed, it had already been modified to clear the exhaust manifold - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0506.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0507.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0508.jpg All cleaned to bare metal - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0509.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0510.jpg And painted in Silver Engine Enamel - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0511.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0512.jpg Fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0513.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0514.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0515.jpg Next I moved onto the plenum which was in a sorry state - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0516.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0517.jpg Throttle Body removed - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0518.jpg And here is what we are going to fit, an Escort Cosworth small turbo Throttle Body with an integrated Idle Control Valve - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0519.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0520.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0521.jpg Link to comment Share on other sites More sharing options...
sidrick Posted August 1, 2013 Share Posted August 1, 2013 Great update as usual. Link to comment Share on other sites More sharing options...
