martinw17 Posted June 7, 2013 Share Posted June 7, 2013 hello guys anyone fitted a double din head unit into a mk 6 escort if so is it hard to fit in properly thank you guys Link to comment Share on other sites More sharing options...
shawdreamer Posted June 7, 2013 Share Posted June 7, 2013 hello guys anyone fitted a double din head unit into a mk 6 escort if so is it hard to fit in properly thank you guys If its a true 2din and not a 1.5din (which are often wrongly identified), then it'll take a bit of work trimming the upper and lower edges of your existing standard escort ford radio slot, sometimes you can get away with just trimming away the small 5mm lip at the top and bottom and itll just squeeze a 2din, other times you have to be a bit more "aggressive" to make it work. either way its not entirely impossible to do with a dremel or hacksaw blade and a half decent file, in such a way tha it doesnt look a mess once the stereos in. Link to comment Share on other sites More sharing options...
martinw17 Posted June 8, 2013 Author Share Posted June 8, 2013 im shire its a proper double din as does not fit into stereo hole thanks and will give it ago thanks Link to comment Share on other sites More sharing options...
POSTIE Posted June 9, 2013 Share Posted June 9, 2013 if u take out the tape holder bit under the head unit cit the strip out thats left file it down so its the same as the outher edges the u can use a fascia fron a single head unit cut the top of so u only have the bottom part if it is one with a metal back srew a couple of tags that can flip over to secure it and then u can fit head unit as normal Link to comment Share on other sites More sharing options...
martinw17 Posted June 9, 2013 Author Share Posted June 9, 2013 ohhh niccee one mate thank you u mean cut the whole plastic bit thats lest there when u take tape holder out n u got a piccy mate thank you Link to comment Share on other sites More sharing options...
POSTIE Posted June 9, 2013 Share Posted June 9, 2013 ohhh niccee one mate thank you u mean cut the whole plastic bit thats lest there when u take tape holder out n u got a piccy mate thank youyea theres a thin plastic strip thats let that u have to cut out um theres a pic in show me ur car under mk5 van update but ill sort a better pic tommro for u Link to comment Share on other sites More sharing options...
martinw17 Posted June 12, 2013 Author Share Posted June 12, 2013 hi have u got a better pic of how u fitted the double din and omg your van is awesome thanks Link to comment Share on other sites More sharing options...
