bongo Posted June 17, 2013 Share Posted June 17, 2013 right my original gauge didn't work (did until RS conversion) put the tired old rs clocks in and the temp gauge goes straight to red as soon as i move to key position number 2.does the same whether i disconnect it from the temp sender or leave it connected? any ideas? Link to comment Share on other sites More sharing options...
scottybo Posted June 18, 2013 Share Posted June 18, 2013 i had something very similar on an old mk3 fiesta, that was down to the sensor tha screwed into the block being snapped though Link to comment Share on other sites More sharing options...
bongo Posted June 18, 2013 Author Share Posted June 18, 2013 i had something very similar on an old mk3 fiesta, that was down to the sensor tha screwed into the block being snapped though does it if the sensor is connected or not. Link to comment Share on other sites More sharing options...
bongo Posted July 28, 2013 Author Share Posted July 28, 2013 anybody else had this who's done the rs conversion? father in law has been and checked. he seems to think the output from the ecu to the gauge could be naffed,so need to know what the temp gauge wire no 7 on the white plug....white/green,where it goes to on the ecu...(rs2k dads ecu) Link to comment Share on other sites More sharing options...
bongo Posted July 29, 2013 Author Share Posted July 29, 2013 right update on this,traced wire from back of gauge white/green goes into fusebox and out,got 2 plugs coming out of the wing on drivers side under scuttle,on the plug from the fuse box (zetec loom) i have 2 wires that are white/green,the plug then from the rs2k ecu which plugs into this has a black/green wire going to 1 of the wires but the other is blank ( the zetec temp gauge needs 2 inputs the rs only uses 1)so this is why the gauge reads max,its not getting a pull from the ecu to bring it down. so how do i get around this? do i just join the 2 white/green wires so they both go to the rs's 1 black/green wire? help please guys. Link to comment Share on other sites More sharing options...
bongo Posted July 29, 2013 Author Share Posted July 29, 2013 scrap the above,im a idiot a didnt even see or realize there's a guage sender underneath the thermo housing that you cant see from above,,what a cock i am lol. Link to comment Share on other sites More sharing options...
JC Posted July 30, 2013 Share Posted July 30, 2013 is the problem solved now? Link to comment Share on other sites More sharing options...
bongo Posted July 30, 2013 Author Share Posted July 30, 2013 hopefully tonight,going down the garage for an hour. Link to comment Share on other sites More sharing options...
bongo Posted July 30, 2013 Author Share Posted July 30, 2013 nope grounded the earth and took the other to the other white/green and nothing. anyone know what this plug is below the airbox,it has a white/green single wire. http://www.evo-host.co.uk/getimg/31339.jpg Link to comment Share on other sites More sharing options...
bongo Posted July 31, 2013 Author Share Posted July 31, 2013 have now found out that i dont have a plug in my engine loom (rs2k mk6) to plug onto the temp sender......investigating continues lol Link to comment Share on other sites More sharing options...
