martinw17 Posted June 23, 2013 Share Posted June 23, 2013 hi guys iv got a double fog light switch with 5 wires coming out of it for the front fogs iv brought this Pre-Wired Accessory Lighting Fitting Kit RLFK200 fog light wiring kit and wondering if i could wire to standard switch thanks guys oh comes with relay as well Link to comment Share on other sites More sharing options...
martinw17 Posted June 26, 2013 Author Share Posted June 26, 2013 anyone please thank you Link to comment Share on other sites More sharing options...
shawdreamer Posted June 27, 2013 Share Posted June 27, 2013 hi guys iv got a double fog light switch with 5 wires coming out of it for the front fogs iv brought this Pre-Wired Accessory Lighting Fitting Kit RLFK200 fog light wiring kit and wondering if i could wire to standard switch thanks guys oh comes with relay as well you can as the oem switches are incredibly basic affairs but Id advise against it cos simply put.... their as delicate as they are simple and showing them anything but ford spec's usually see's them burning out with sheer panic. Link to comment Share on other sites More sharing options...
martinw17 Posted July 2, 2013 Author Share Posted July 2, 2013 hi got a plug for the front fog switch a purple yellow, orange and purple, blue purple, purple and black wires any one got any ideas how to wire this to my fog wireing kit thanks this is the wireing kit i got Accessory Lighting Fitting Kit RLFK200 thanks guys Link to comment Share on other sites More sharing options...
dalelc16 Posted July 2, 2013 Share Posted July 2, 2013 Hi this can be done but the normaly go to the fuse box.On some escorts the wires under the engine are there and the standerd plug behind the dash so you can conect the button straight away with no fuse.If its a mk6 the plug which goes to the switch can be taped up against the other plug which goes to your rear fog light.The plugs which are going to conect to the fogs on you bumper may be taped up around the front of the car some place.Have a look you might not need to add wires Link to comment Share on other sites More sharing options...
martinw17 Posted July 2, 2013 Author Share Posted July 2, 2013 hi mate iv looked pal there bugger all mate any ideas on how to wire switch thanks mate Link to comment Share on other sites More sharing options...
dalelc16 Posted July 2, 2013 Share Posted July 2, 2013 hi mate iv looked pal there bugger all mate any ideas on how to wire switch thanks mate You cant realy go wrong fit the light and wires and add the switch and try each wire on the back off the switch until it works.One will be a live one will neg and a earth and the other on will be the light to light the swich. Link to comment Share on other sites More sharing options...
