roboboyo Posted June 30, 2013 Share Posted June 30, 2013 Anyone ever had a loose eprom in their ecu???? what where your symptoms, as my ecu would appear to be fatly, Ive been having this idle problem, the car will run, but all of a sudden, it will act like its miss firing and when i idle, she cuts out (only after the miss fire) I left it with a mechanic, who im begining to lose faith in, because after the 2 days searching for my problem, he told me i need a new engine, in my opinion, he was defeated by the problem, and wanted the easy way out, he told me the rings may be finished!!!!! im not burning oil or water, and she pulls well, its only the inconsistent lumpiness and rev drops, and cut outs, witch dont happen all the time. ive changed the ispv, ive changed the coil, ive changed the maf, ive changed the ht leads, ive changed the oxy sensor, all for new parts, ive also swapped for a known working fps and tb. took my car to 2 different mechanics, and they both said, that my problem was not anything to do with engine compression, but there is a problem around the inlet mani, anyone got any advice ???? Link to comment Share on other sites More sharing options...
dalelc16 Posted June 30, 2013 Share Posted June 30, 2013 Anyone ever had a loose eprom in their ecu???? what where your symptoms, as my ecu would appear to be fatly, Ive been having this idle problem, the car will run, but all of a sudden, it will act like its miss firing and when i idle, she cuts out (only after the miss fire) I left it with a mechanic, who im begining to lose faith in, because after the 2 days searching for my problem, he told me i need a new engine, in my opinion, he was defeated by the problem, and wanted the easy way out, he told me the rings may be finished!!!!! im not burning oil or water, and she pulls well, its only the inconsistent lumpiness and rev drops, and cut outs, witch dont happen all the time. ive changed the ispv, ive changed the coil, ive changed the maf, ive changed the ht leads, ive changed the oxy sensor, all for new parts, ive also swapped for a known working fps and tb. took my car to 2 different mechanics, and they both said, that my problem was not anything to do with engine compression, but there is a problem around the inlet mani, anyone got any advice ???? Cambelt might of slipt I had this problem and the timin was out by one grove Link to comment Share on other sites More sharing options...
scottybo Posted June 30, 2013 Share Posted June 30, 2013 if theres a known issue around the inlet manifold then start there. replace all the gaskets to ensure there is no leak. i would have suggested a compression test but u said that has been done. otherwise check every plug, connecter and earth for breaks or corrosion and lastly...try a working ecu that u know is good Link to comment Share on other sites More sharing options...
the_big_man Posted June 30, 2013 Share Posted June 30, 2013 May be worth trying the valve which is on the crankcase breather on the front. These are knwon for playing up at times and causing idle issues http://i6.photobucket.com/albums/y247/l99amm/Escort.jpg Link to comment Share on other sites More sharing options...
demented Posted July 1, 2013 Share Posted July 1, 2013 That'll be the PCV valve. Think he's replaced it. Link to comment Share on other sites More sharing options...
scottybo Posted July 1, 2013 Share Posted July 1, 2013 as i said on your other thread, maybe check fuel pressure? Link to comment Share on other sites More sharing options...
roboboyo Posted July 1, 2013 Author Share Posted July 1, 2013 as i said on your other thread, maybe check fuel pressure? what would cause fuel pressure to be low??? Link to comment Share on other sites More sharing options...
JOHNDQ Posted July 1, 2013 Share Posted July 1, 2013 (edited) Most likely cause would be a faulty pump Edited July 1, 2013 by JOHNDQ Link to comment Share on other sites More sharing options...
roboboyo Posted July 16, 2013 Author Share Posted July 16, 2013 Most likely cause would be a faulty pump pump changed, same issue, Injectors??????????? Link to comment Share on other sites More sharing options...
scottybo Posted July 16, 2013 Share Posted July 16, 2013 have u checked the wiring loom.for breaks or corrosion? Link to comment Share on other sites More sharing options...
